 Originally Posted by
mrtew
				 Obviously there must be some that didn't get posted here, but a 1% failure rate would be over 600 engines.
From you, Sry just a little anal about math.
I'm still sold on buying a VX btw. All cars have some failures, one thing I noticed if it's true, hard to tell from just pics. Does the PCV valve lay on it's side? They need to be straight up to really work right.  Also are there really no rocker arms? I'm curious how the cams actuate the valves. And how you adjust the valves. Has anyone just put the 02 oil rings on the 99-01 pistons? This oil usage thing has me curious. Isuzu is know for good quality engines generally.
				Junster    If it don't looked fixed.. It ain't fixed.
