Please allow me to run this by you VX doctors out there. I've done all the searches through the forums and manual and am quite stuck.
SYMPTOMS:
When I'm driving, and make a 90 degree turn either left or right, my VX makes a creaking/banging sound for a second. It occurs right in the middle of the turn and sounds to me like frame is twisting. It's usually about six or seven quick knocks lasting a second or so total. From the drivers seat, it's sounds like it's coming from the passenger side, but it's hard to discern where. My passenger though, says she can feel the vibration of the knocking on the floorboard under her feet (which is right around where the transmission assembly is).
At this point, there’s absolutely no negative symptoms except for the noise; everything is acting just as it should, no transmission trouble whatsoever. But of course, I fear one day, BAMM; I think it might be telling me that something’s no right. Last year I had a slight leak around the flywheel, but that stopped after I put in stop-leak in the engine & transmission and those fluid levels are fine. Front and rear axles also are good with fluid. What I haven’t done is change the TOD or transfer case oil, because the manual isn’t real clear about how to accomplish that.
I guess I’ll have to take it to a dealership (God help me), but was hoping some here had some insight.
Thanks- Scott
I have the same problem. Has anyone had a similar problem or found a definitive answer?
