Results 1 to 7 of 7
Thread: will this wheel size fit?
    Nov 2003
    1999 black VX 1740
    Just wondering about this wheel size for my VX?
    Size: 20" X 9.5"
    Bolt Pattern: 6 X 5.5/139.7mm
    Offset: 10mm
    thanks guys/girls
    ~K
    2001 Black, Black, and more Black
    The bolt pattern is fine, but that's a wide wheel. Gonna stick out from the fenders almost 2.5" more than the stock wheels.
    Whether it'll fit or not really depends on the tires you choose.
    -Daver
    -Daver
    Nov 2003
    1999 black VX 1740
    Hey Daver!
    Thanks for your reply
    Do you have any idea of the size of our stock 16" rims?
    What size tires would you recommend for the 20" x 9.5" ....the less they stick outside the fender the better.
    Thanks again,
    ~Kiersten
    Mar 2003
    Are you looking at a particular wheel? Be sure that it is compatible with the VX's hub... that bolt pattern is the same as most full size chevy/GMC trucks too... but they won't all fit due to the larger hub's on foriegn vehicles like the VX... at one point I was eyeballing a set of Weld EVO wheels but turns out that the hub wasn't compatable... soo... check to make sure... if you don't know for sure, try to buy from a reputable, local dealer that will test fit them... just an idea.
    TTYL!
    Nov 2003
    1999 black VX 1740
    Hey Randy
    check ur PM
    ~K
    I have an 18x8.5 with a 0 offset and they still stick out a good 1". In my opinion, it doesnt look too bad at all, but my state law says no no. As far as just looks though, 1" seems like the furthest I would go on it, unless I lifted it up and stuck some big old 38"s under there. A 9.5 sounds rather heavy for the VX and will surely cause handling changes in your ride. Without a lift, you will surely be doing some heavy trimming too, and I mean HEAVY.
    Stock lift with Enkei 18x8.5s and Yokohama AVS 285x60s.
    Good luck on your new shoe endeavor.
    Nov 2003
    1999 black VX 1740
    Yeah.....that looks WICKED!
    I'd say 1" is about the most I'd like the wheels to stick out....What make of wheels/tires are those WormGod?
    I decided against the 20" x 9.5" after all the info from you guys
    I'll probably go for the same wheel in a 20" x 8.5" with a 6 offset.....but what makes the wheels/tires stick out so far? Is it the offset or the 8.5 measurement?
    Thanks again guys !
    ~Kiersten
  1. Wheel stud size?
    Last Post: 12/13/2008, 03:36 PM
  2. Wheel Size Question
    Last Post: 07/06/2007, 12:06 PM
  3. max wheel and tire size??
    By mnsnutn in forum VX Modifications...
    Last Post: 09/29/2006, 08:40 PM
  4. Wheel Size
    Last Post: 03/10/2006, 06:53 PM
  5. tire use and wheel size chart
    By doubleadesign in forum VX Troubleshooting...
    Last Post: 02/24/2004, 07:37 AM
