Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: VX Lifts...
    Jun 2003
    99, Ironman VX, 1455
    Spazz,
    I am very interested in the details you mentioned about locking out the hub for less wear and tear, but I don't understand it completely. Hate to be a NeewwwBEEE,. but any chance I can get more details? These are the questions I have so far:
    it saves wear and tear on cv's when you do not need TOD... a TOD disconnect switch would be better to totally disable front power and it also saves on mileage...
    How does it save wear and tear? How do I go with a locking hub and then does that dissable the TOD or just force it to be in 4 wheel.... also, how do you get a TOD Disconnect switch? Do you think its a pain in the arse to install?
    I ask these questions because I like TOD for street, basic dirt roads and snow, but sometimes when I am wheeling I don' tlike that it doenst engage in 4 wheel untill there is slipage or loss of grip. Please let me know if I am wrong, but wouldnt it be less risky if it was always in 4 wheel. For example, I would hate to have my car slip of a boulder and do damage because 4 wheel didnt engage until it was at a bad angle, vs already having full control going into the boulder. Right now I spend a lot of time going into 4 low just to make sure i have full control.
    What is a waste of gas? How much savings do you think it will offer or what better mileage do you project with not having TOD? I don't see how the two are related.
    Gracias!
    -The Rave-
    North Carolina
    ! Wanna Retire...I bought my springs for $133 and then add another $40 for an alignment.
    95trooper
    Another option, is to use poly spacers. The Old Man Emu springs have a different spring rate than stock. They will give you about 1.5" of lift. If you want to keep stock spring rate or lift VX more/less than 1.5", then the spacers are probably a better choice. The spacers come in 1", 2" and 2.5" lift. They will run less than $100. Checkout the daystar web site for more info.
    Also, on the manual hubs, you will have to add the TOD disconnect switch if you add manual hubs. If you run TOD, with unlocked hubs, it confuses TOD and you will get an error light. I found this out w/ my '01 trooper. That said, the hubs and TOD disconnect switch are worthwhile mods. Aside from saving driveline wear, the setup removes quite a bit of driveline friction. Mileage will and ride will improve slightly.
    '95 Trooper LS w/ 5spd, front lockright, rear LSD, Tera Low, 1.5" OME coils, 2.5" Daystar spacers, Nissan Patrol RS9000s, ARB Bullbar, Warn M8000, 33" Firestone Destination MTs, SURCO rack.
    95trooper
    here's a link to boot replacement for an isuzu.
    http://www.4x4wire.com/isuzu/tech/CVboots/?
    '99 Ebony VX #0038
    Thanks, wareagle! That's exactly what I was looking for. I'm pretty sure I can just replace the boot because it hasn't been torn very long. We'll see when I get in there.
    '99 Ebony VX #0038
    Well guess what? Those instructions were excellent, and I had no major problems getting the half axle taken apart and rebuilt. Then, when everything was almost complete, I found out the part the local auto parts store sold me was not the right one! The boot was about 1/8" too large (in diameter). Soooo, I had to tear everything apart again and drive to a parts store an hour away to get the right one. I'll post a write up / howto when I get everything completed tomorrow.
    My advise - anyone with cranked torsion bars should pay close attention to those CV boots. If one tears, you can fairly easily fix it if you catch it son enough and save yourself the cost of a new axle.
  1. Guys with Body lifts?
    Last Post: 10/28/2014, 11:00 AM
  2. Lifts & wheels Dazed and Confused
    By Pigpen in forum VX Talk...
    Last Post: 07/21/2005, 05:13 PM
  3. Body Lifts
    By projectVX99 in forum VX Talk...
    Last Post: 03/21/2005, 01:57 PM
