Results 1 to 15 of 22
Thread: Major Electrical Problems, PLEASE ADVISE....
    Jun 2003
    99, Ironman VX, 1455
    Angry Major Electrical Problems, PLEASE ADVISE....
    Its late, so I am going to spit this out as I know the next 48 hours are going to be extremely busy at work. I just picked up my Vehicross from the body shop and the it looks unbelieveable. The money I paid for the paint job is worth it, however, I am afraid it looks too good for wheelin' now, but wheelin' is all I want... I'll get over it. I pressed the guy to get it done, he's had it for 10 days, and I have to take it back in a few weeks to get it buffed again and to get the window trim's replaced... However, there are some major glitches in the VX and was hoping to get advice here so I can give him a hand in figuring out the problem. Its electrical, along with a few others.
    1st Big One: Hard Shifting.... the shifting between 1st and second, reverse, netrual, 4th, everthing feels like a brick is dropping. How could htis have happened when all that was mechanically installed was the stinkfab links... The body was painted thats it, but he must of messed somehting up to make it shift so bad....
    2. Electrical Problem: THis is a doozy.
    a. the Instrument Panel Gear Reader (sounds so corny, but I don't know what it is called) isn't lighting up, it shows what gear it is on in the middle console, but not in the instrument Panel...
    b. Reverse Lights Not Working
    c. Cruise Control can be turned on, but I can't get it to engage when clicking on the button on the steering column.
    d. Windows Don't work
    e.Blinkers wont work
    Dang it, thats a lot of important stuff not working. The people kept taking the fuse out and it was burning out, they were checking to see if something was miswireed, and couldn't find anythign.... Based off of everything that is wrong, can anyone offer any advice? COACH? You seem to know a lot about mechanical stuff, any advice?
    Your help is greatly appreciated, I am posting pictures tomorrow when I get a chance!
    -The Rave-
    North Carolina
    Dec 2003
    99 white Ironman 0922
    Hi NC_VX
    Remember that any paint job looks unbelivable when is fresh, once it is cured it might turn ugly.
    VX922
    Selector light out on dash and hard shifting is the classic symptom of the tranny mode selector being blown or shorted - search here for several causes. Sounds also like a ground has come loose or unconnected to cause the other issues. Or the vehicle has been welded on without disconnecting the computer and fried a few things.
    Mar 2004
    1999, silver, vehicross, 1155
    i'll second the welding theory!!!..(if any welding took place)..i have experienced it first hand with other personal custom vehicals in past.....you would be quite amazed at the strange things it can cause to happen by subjecting the vehical to welding without proper grounding and shorting of chassis.....
    i mean just take it back to him and let it be his problem to fix....it was fine when it came in! should be fine coming out, but looking twice a nice with new paint.
    Jun 2003
    dramatic experience
    its not the welding, cause that didn't happen, but I appreciate the direction you guys are taking this. I've got a few more details for you.
    The fuse that blows is the signal/rear light fuse and it blows only when in reverse, and it blows immediatly. The body shop only took off the cladding to paint and so they think there might be a wire not grounded or broke somewhere since it happens so fast. Once that fuse burns out, the blinkers, windows, cruise don;t work....
    I am going to take a look at the electrical wiring to see if anything jumps out at me, but I took the car to a local Isuzu dealership, and although they were all GaGa over it, they had no advice. Actually, one dude (Master Electrical Mechanic) said that the reason the tranny was shifting so hard was probably because of the fuse. I can somewhat agree that all the problems are related, but I plug in a fresh fuse (and don't use reverse) and the thing still shifts bad.... However, if I have high RPMs then it shifts like normal, so I am mannually shifting and keeping the RPMS up there for the next few days until I can come up with something.
    MORE ADVISE ANYONE????
    Thanks.
    Thanked: 7
    Post
    Dont know if this is your problem but I would check CLOSELY the wiring harnesses running through the engine department including the harness that runs below and behind the driver side headlight. Frayed wires grounding out can blow fuses and cause the weirdest power outs including the ones you describe. Some of us have experienced it firsthand.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Jun 2003
    thats what I'm thinking too, thanks for the words Anita!!! Can't wait to meet you someday, you seem to always have nice things to say about people and seem to be the "mom" of all these guys on the site!!!
    Thanks
    Jun 2003
    Question
    I noticed that the lights were crooked or not shining right on my VX, so today I went in and straightened them... Basically the driver side was not fully clipped in and the passenger side was not all the way in the socket, where the triangles meeet... I had to take the battery out, along with the air intake to get to the lights, I dind't see any exposed or damaged electircal in that area, but I knoew they took that crap appart to get my lights out.... Hard SHIFTING? Not anymore, and I haven't tried reverse to see if the fuse will burn since I don't have a spair right now... I hope the lighting could h ave been the cause of all the problem.... Probably not, but the shifting is gone... However, I seem to be getting "shocked" more when I get out of the truck today....
    Any thoughts?
    Jun 2003
    After searching this thread: http://www.vehicross.info/forums/sho...ght=Electrical would make sense for my issue since they took the front bumper off. I also fixed the front headlights being crooked so hopefully that will do the trick. Will let you all know how things go this weekend when I take a look!
    Mar 2003
    How are things now? Any better? From reading your description of your problems and blowing fuses... and the fact that they had removed the cladding and all... sounds to me like they had pinched a wire somewhere causing a short... basically taking 12V to ground... will instantly pop fuses. I would look for any harnesses that could be pinched between the cladding and body panels... did they remove anything else other than cladding? And let us know if there is any definite change since you messed with the lights.
    Jun 2003
    Unhappy STILL BLOWING FUSES
    No luck yet. The headlight problem solved the headlight problem (poor quality view) and nothing else. I think I am going to take the intake apart and dig around in there to see if I can see any pinched or exposed wires. If I do? CAN I JUST PUT ELECTRICAL TAPE AROUND THE WIRE AND CALL IT A DAY?
    The Fuse Keeps Blowing in reverse, but it I put the fuse in after I moved the truck in the position to drive and the truck was turned off, then no clonking in shifting and everything works fine. INteresting note, if the fuse blows while engine is running and I just pull it out and stick another in, the windows, blinkers, cruise all work, but it still shifts like a B.... So, why is that?
    I am taking it back to the shop this Saturday to figure some things out!!!
    Feb 2004
    2001 Silver Vehicross 0273
    Unhappy Electrical Problems Seconded
    If you don't mind, please keep me in the loop on your adventures. My Vehicross has developed a similar problem where turning on the headlights is immediately blowing out fuses that control the parking lights and Dashboard illumination. I'm going to try to get it to a dealer but this sounds like finding a needle in the haystack!
    Pull the taillights and check for pinched or shorted wiring. Are all your parking and license plate lights working? Pull the door sill plates too.
    Since it sounds like all this developed after having the cladding and lights removed, it's possible they pinched a wire when reassembling .
    Jan 2004
    2000 Black Trooper 3248
    NC_VX, your problem is not as bad as it seems. You have the one advantage when it comes to diagnosing electrical: Consistent behavior. You may need an EWD (Electrical Wiring Diagram). What you need to do is buy a bunch of fuses, and "split half" the circuit that has the problem. You'll have to reproduce the ground at each connector (to simulate the switch), but keep disconnecting each connector in the harness closer and closer to the problem until you isolate the segment of harness or component that is causing the short. If it's in the harness, you'll likely find some "trauma" in the area. I wish you lived near Denver; I could help you find the problem in a hurry.
    Good luck.
    Nate
    Jun 2003
    SGT., the body shop boys pulled the rear lights and the door sill plates while I was there, so I hope that the problem is in the front and will be quick to find.
    Nater, I don't understand your process, but i will figure it out today!!!
  1. Electrical Problems
    By dmanske@cavtel.net in forum VX Talk...
    Last Post: 01/04/2012, 07:02 AM
  2. New Head Gaskets Major Problems
    By BHP in forum VX Troubleshooting...
    Last Post: 01/27/2008, 08:45 AM
  3. Major Electrical Gremlins!!!
    By grober02 in forum VX Troubleshooting...
    Last Post: 11/15/2007, 12:14 PM
  4. Electrical Problems...
    By Jolly Roger VX'er in forum VX Talk...
    Last Post: 08/18/2003, 01:32 PM
  5. Replies: 5
    Last Post: 03/21/2003, 08:13 PM
