This is for those of you that have the TOD disconnect installed. The switch for my TOD disconnect broke the other day so now i just have the wire twisted together. While driveing i noticed the ABS light was on. After playing around for a while I figured out that if you touch the disconnect to a ground momenteraly it turns off the ABS. this has to be done when the TOD is functional it does not work if TOD is turned off. I have no idea if this would cause any problems in the computer by grounding it out. If anyone knows if it would cause a problem please let me know. If there isn't any reason for concern then this would be great for those of you that don't like having ABS while offroading, or for any other reason.
