Results 1 to 11 of 11
Thread: ABS light came on
    1999 silver 1346
    ABS light came on
    I was driving today and noticed my abs light was on, I never seen this before and dont seam to be any reason for it to be on. Brakes seem fine. Anyone know what can cause this and a fix for it? Could it be a sensor and if so how hard is it to replace?
    I also have the OEM brakes and 70,000 miles on the car but i checked a few weeks ago and still have some meat on them.
    adam
    Sep 2003
    1997 ,silver vehi-cross,0091
    hi zadam
    that happend to me aswell came on for no reason
    the fix disconnected battery for 5 mins reconnect
    and its been fine not come back on since
    worth a try
    1999 silver 1346
    lenny.
    I also noticed that the abs does not work , I tested out today and car skided to a stop rather than the controled stop. did yours do that as well?
    thanks
    adam
    May be a damaged sensor or wiring. Can a code be read?
    1999 silver 1346
    Do you need a special tool to read the codes and if so where can i get one?
    I think either pep boys or autozone can pull codes. Either featherfoot or hotsauce posted a pic of an ACTRON code reader that runs about $150- $200.
    Have you checked your brake fluid level? Seem to remember some posts that may have solved this problem, but don't recall if it was brake or abs light.
    1999 silver 1346
    Originally posted by lenny
    hi zadam
    worth a try
    Thanks for the idea but i tried that and still came back on
    adam
    1999 silver 1346
    OK wnt to a local shop to read the code and he said it was
    B-12 which he said was a front right holding solenoid.
    any ideas what this is and how much bread this is gonna cost? The mechanic wont know till monday if he can get it fixed.
    adam
    '01 Ironman
    That was me and it was the brake light not ABS.
    -FYI, A couple times after spinning a bunch of braodies the ABS light would come on, but as soon as it was shut off and restarted the light would be off.
    1999 silver 1346
    Today the mechanic i went to was supposed to tell me wether or not he can fix the car. after he called isuzu he was told that they dont know that code and he must have used a scanner other than isuzu's and that i would have to bring my car to isuzu to find the problem since it seams that diffrent scanners put out diffrent wording as to what the problems are. I even called isuzu and was told the same thing.
    Heres what sucks.
    I gave this guy $60 to tell me whats wrong with my car and even made sure to ask befor he started if he would be able to find the problem and fix it and like everyone else who dont know about the VX he assured me he would. now i have to go to isuzu since he has no idea whats wrong (isuzu told him they never heard of a front holding selonid) and have the scan run again at there price of $85 and the first guy wont even give me my money back even though he really did nothing for me.
    adam
    2001 Proton VX 0790
    Just a suggestion, pull the ABS sensors, and wipe them clean. When I was repacking my front wheel bearings i noticed that the ABS sensor was covered with brake rotor shavings that cling due to the magnets in the sensor. I could imagine enough of this causing an error code.
    John C.
  1. Help with wiring light acces. to dome light
    Last Post: 11/24/2013, 08:49 PM
  2. Battery Light, ABS Light, No Power
    By TimG in forum VX Troubleshooting...
    Last Post: 03/22/2012, 08:23 PM
  3. Rear cargo light + underhood light
    Last Post: 05/29/2010, 08:00 AM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 08:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 07:49 PM
