Results 1 to 10 of 10
Thread: Chaging fluids...
    Feb 2004
    2001, SUPERCHARGED!
    Chaging fluids...
    Ok, I want to run out and buy the best fluids to change out my transmission and differential(sp?)
    Questions are:
    How much do I buy for each and what are the best?
    Thanks- Jay
    Draftsman of the dead
    '99 SC Ebony #1961
    Feb 2004
    2001, SUPERCHARGED!
    Cool, I'll go with the Mobil 1.
    To get this straight,
    Tranny 10 quarts?
    front and rear diffs 4 quarts?
    '01 Ironman
    Don't forget the X-fer case, I think its another 4 quarts?
    '99 SC Ebony #1961
    My Isuzu shop used:
    14 qrts (Mobil 1 ATF) for the tranny flush and fill
    3 qrts (Mobil 1 ATF) for the transfer/TOD cases
    4 qrts (Mobil 1 Gear Lube Oil 75w 90 )for the diffs/ also added a lsd additive to the rear diffs.
    5 qrts (Mobil 1 10w 30) engine oil
    Feb 2004
    2001, SUPERCHARGED!
    Got it, thanks guys!
    '99 Astral #1977
    If you are not having the trans flushed, you will NOT need 10 to 14 quarts of trans fluid. IIRC... I used 4 (?) for drain and fill.
    RichD
    Tranny capacity with converter is only 9.1qts and you will only get 3-4 out with a regular drain and fill.
    Feb 2004
    2001, SUPERCHARGED!
    Should I change out the trans filter(30K)?
    Yes, you should. It requires supporting the trans and dropping the crossmember to remove the pan.
  1. AHH!! wrong fluids
    Last Post: 05/30/2006, 09:14 PM
  2. fluids changed
    By tngerman2000 in forum VX Troubleshooting...
    Last Post: 03/04/2006, 04:48 PM
  3. changing all fluids
    By thedutchguy in forum VX Troubleshooting...
    Last Post: 10/17/2004, 12:08 PM
  4. Fluids question...
    By Cyrk in forum VX Talk...
    Last Post: 04/01/2004, 07:41 PM
