Joe_Black - The MityVac accessory you spoke of - I'm assuming that is some sort of vacuum attachment? Can you elaborate?
Is that the only way to do a complete flush, besides taking it to a shop?
The MityVac accessory is, to my knowledge, the closest you can get to a flush at home. You won't get all the original ATF the first go, but will notice a significant improvement. Cyrk didn't necessarily get ripped, he just paid to have someone take care of the whole process for him. And the fact he's all smiles is testament he made the right choice for him!![]()
And as Tone mentioned (I forgot to, sorry!) you do need to replace the filter in the process.
i love my mighty vac, its the best $30 ive ever spent on a tool.Its a hand held vacuum pump with a vac gauge and varoius hose attachments for syphoning fluids and even can be used as a transfer pump. makes flushing the brake system a snap, and a ton of other uses, including testing the vacuum hoses and all that.. ive even heard of people using it to test the cooling sytem (including one who collapsed his radiator accidentally in the process, so ive shyed away from that particular use.)
Ive decided im going to pay someone to flush my tranny correctly, but the rest is me, my mighty vac, and mobil one![]()
Maverick
99' Ebony VX sold...
I was under the impression they do a reverse flush (atleast where I go) that push debris out of the filter, via the tranny cooler, thus flushing the whole system... thats what it looked like to me-
face the mirror
Regardless of what brand fluids you use in your tranny...
I was looking around on Amsoil's site just now and I found this:
http://www.amsoil.com/lit/filter_man_council01.pdf
It's actually some sort of Tech Service Bulletin and it explains the "flush and fill" without removing the pan.
This is right in line with what Tone and some of the other guys have said!
Good info here in "12 easy steps to change transmission fluid"...???
http://www.amsoil.com/products/atf.html
Maybe the guys with experience doing this can tell us if it is this "easy"?![]()
Joe
Sorry,I cheated...we have the machine at work. Filter change is vital, after 20 or 30000. Simply draining it, only got 4.5qts. out.
Joe....real easy. Take your time, follow the steps, don't break out the beer an' such till putting the pan back on. (Step#13) they left that one out.
Thanks Chopper... that's an important step!
(closely followed by getting the grill warmed up to make some burgers afterwards)![]()
Joe
Bit brisk in steeltown for a cookout is it not? Call for the ribs.
Never too brisk for some grill action!![]()
(in my best Homer Simpson voice): uuh, ribs!
Joe
Is that method as good as a complete flush?![]()
Formerly VxRaNgEr
Personal opinion...... better. I never liked the idea of forcing gunk and the little metal bits out of the sludge and filter, back thru the system. Some is bound to end up where you don't want it. Crack it open, everything comes out the bottom, and everything gets as clean as you wish. Hint; when we do a customers car,it's strictly flush an' fill... When I do boss' 35 Ford Cabriolet (5.0 swap) or any of his toys, ALWAYS crack, clean, an' refill with synth.![]()
