Results 1 to 15 of 27
Thread: Synthetic in the Differential?
    2000 Ebony Black #0096
    Question Synthetic in the Differential?
    A friend who's a die-hard Subaru-owner suggested using synthetic lubricants in my VX's differntials.
    Sounds like a good notion, but what would be the advantages?
    Any other thoughts?
    ...behold a government which to bigotry gives no sanction and to persecution no assistance...
    1790 Geo. Washington
    Nov 2002
    Mobil-1: Lower friction, better thermal performance, longevity, uniform molecular structure, better contaminant supsension, all sorts of wonderful things. Besides, your Ebony will love you for it! Just remember to get the LSD additive for the rear diff. I've got pics in my gallery of the fill and drain points too.
    '99 SC Ebony #1961
    I just had my transmission flushed and refilled with Mobil 1 ATF synthetics and the differentials filled up with Mobil 1 75w 90 synthetic Gear Lube and added a LSD additive in plus the oil change with Mobil 1 10w 30 synthetics...
    The VX shifts SO much smoother and seems faster to redline?
    I am very happy i went this route. I feel with the SC installed this is the best way to treat her to some good stuff.
    Joe, sold me on Mobil one before... check this thread for some more info:
    http://www.vehicross.info/forums/sho...&threadid=3390
    -Dave
    2001 Ebony 0177
    DITTO!Did this with47mi. on the ODO,the dealership was 35.8 miles from home. If you love it, treat it that way.
    Feb 2004
    2001, Kaiser 1188
    Gonna change diff/t-case fluids before my Utah trip. Is it worthwhile to have my tranny flush 'n filled as well? How much will shop charge for this if I bring the oild to them?
    Formerly VxRaNgEr
    '99 SC Ebony #1961
    my guy charged me 200 and I brought them all they fluids the also flushed the radiator.
    Feb 2003
    $200 !!!!!!!!!!!!!!!!!
    FOR $200 PLUS YOU BOUGHT THE FLUIDS........I change all the fluid out of every stinking thing that has fluid in your VX;eekp; ...............
    Just got a coupon from my dealer, Trans flush= $89
    Feb 2004
    2001, Kaiser 1188
    Ouch....maybe I'll wait. ;eekr;
    Nov 2002
    Lightbulb
    Yike!;eekg; You can do the change yourself, but it's not a flush. It'll probably leave a couple quarts of the previous ATF but Mobil-1 is fully compatible so it'll blend with no adverse results. The next change will get the rest out. MityVac make an $89 accessory that make the job real easy.
    A flush is the ONLY way to get all the fluid changed out in a tranny - all 9.1 qts. A drain and refill only gets about 3-4 qts out and leaves the majority of the old fluid in. Dropping the pan and changing the filter gets the same amount but should be done every other change IMHO and is good to do after flushing with synthetic since that fluid has a longer life. Although it is a chore, the filter will not clean itself and a clogged filter will eventually kill the tranny.
    '99 SC Ebony #1961
    Did I get ripped? Oh well, it was well worth it. Drives so much smoother now... plus I did not have time to get dirty...
    Jun 2003
    1999, White, Ironman, 1626
    Tone - So you're saying to get the pan dropped (fliter changed) and drained AND a flush-and-fill at the same time?
    or
    Get it flushed and filled (all 9.1 qts) and then next time drop the pan and change the filter?
    I think I really need to get this done since I could not find any records proving that a 30k mile service was done to my VX
    Joe
    '99 Ebony VX #0038
    Joe_Black - The MityVac accessory you spoke of - I'm assuming that is some sort of vacuum attachment? Can you elaborate?
    Is that the only way to do a complete flush, besides taking it to a shop?
    Nov 2002
    The MityVac accessory is, to my knowledge, the closest you can get to a flush at home. You won't get all the original ATF the first go, but will notice a significant improvement. Cyrk didn't necessarily get ripped, he just paid to have someone take care of the whole process for him. And the fact he's all smiles is testament he made the right choice for him!
    And as Tone mentioned (I forgot to, sorry! ) you do need to replace the filter in the process.
  1. Synthetic debate
    By ScottinMA in forum VX Talk...
    Last Post: 03/22/2006, 09:16 PM
  2. Using synthetic gear oil??
    By Tornado in forum VX Talk...
    Last Post: 12/22/2005, 06:45 AM
  3. 10w30 v. Synthetic
    Last Post: 07/01/2004, 11:51 PM
  4. Synthetic Oil and the Oil Filter
    By jeffkics in forum VX Troubleshooting...
    Last Post: 05/21/2004, 07:04 AM
  5. Mobil 1 Synthetic ATF
    By Robert in forum VX Talk...
    Last Post: 02/18/2004, 07:55 AM
