Results 1 to 3 of 3
Thread: TOD Sensor malfunction
skullcap TOD Sensor malfunction 03/03/2004, 07:51 PM
SGT.BATGUANO The check engine and steering... 03/03/2004, 11:08 PM
MrCrowley Youll be hard pressed to... 03/04/2004, 09:47 AM
    2000 Ebony Black #0096
    Question TOD Sensor malfunction
    Last Thusday I drove 5-hours to the North Carolina Mountains in about 60 miles of ice and snow, it should ordinarily have been a 3 hour trip. My little beast was the only thing on the road besides sand ans salt trucks, and a few intrepid little Subies.
    After coming out of the slush, my TOD indicator was all lit-up and remained lit-up until I stopped after another 20 miles.
    The following day, I ran her through a brushless, waxless auto-wash with a nice high-pressure undercarriage rinse. Minutes later, after driving down the highway, I notice the TOD indicatror lit-up, the steering tightening-up and, finally, the red "CHECK" LED illuminating.
    I pulled-over, turned off the ignition, restarted, but still the same happened after driving forward. I stopped again, shidted to neutral, took the 4WD to nuetral and it reset. However, this occurred severalmore times over the next 24 hours.
    Sunday came and it quit acting up, altogether.
    I assume a sensor must have gotten salt-contamination, wet, or both.
    Any thoughts?
    ...behold a government which to bigotry gives no sanction and to persecution no assistance...
    1790 Geo. Washington
    The check engine and steering may have been caused by a wet belt.
    As for the TOD, you may want to check any plug in connectors at the trans for full insertion.
    Also check the wiring harness for abraision where it goes down at the front of the dr. side inner fender.
    Apr 2003
    1999 Astral Silver 1222
    Youll be hard pressed to determine if it was an anomaly or a problem. could have been sand, salt, snow etc. but if its fine now, It may be ok. Under warranty? have it looked at. or at least maybe they could pull the codes and see what the computer thought the problem was. No warranty. maybe do some light 4 wheeling somewhere and see if it does it again.Cross your fingers and Good luck
  1. Which O2 sensor is Bank1 sensor 1
    By Ebenezr in forum VX Troubleshooting...
    Last Post: 08/05/2014, 05:55 AM
  2. Replies: 18
    Last Post: 09/28/2012, 10:44 PM
  3. threshold of TOD malfunction
    Last Post: 03/06/2008, 02:41 PM
  4. O2 Sensor/Coolant Temperature Sensor
    Last Post: 04/21/2007, 12:50 AM
  5. TOD Malfunction ?
    By maxw in forum VX Troubleshooting...
    Last Post: 02/14/2006, 07:01 PM
