Hi Triple X
Welcome...![]()
Your probably out of warranty, but if your are still in? Maybe you should just take it to a dealer and have it checked out. I havn't noted a lot of threads of over heating with this car. But I would still check, as that could be a good source of information and peice of mind.
Questions I would ask myself and check out are:
Does it continue to "diesel" or run after you turn off the ignition?
Does the expansion tank fill up and overflow.
Are you losing coolant?
Does the gauge always show in the mid range...even when you first start in up?
If your unsure of any of this take it to a radiator shop and have it checked, here in the LA area its a $20-40 pop to get it tested.
Don't trust me, but me tinks your just a little edgy cause she's your new baby![]()
Enjoy your new toy!!
