Well this is my first problem I have ever had with my VX. Right now if I start it everything goes fine, but after sitting for 30 sec. it starts to idle high, then you can smell a faint gasoline smell, then it quits. It does not hesitate or sputer, it just dies as if you shut of the ignition. I have a code reader and it states :
Trouble Code : P0101
Description : Mass or Volume Air Flow Circuit Range/Performance Problem
Fuel System Status
Fuel System 1 Status : Closed loop; using oxygen sensor(s) as feedback for fuel control.
I have some more information on the same error code about fuel pressure, and speed of vehicle but I think that is just the jist of it. I think this means I might need to replace my MAF Sensor. If any one can thing of anything else I would love to hear it.
Thanks
Jason
