Results 1 to 5 of 5
Thread: Trans slipping
    2001,Proton Yellow,VX,1046
    Exclamation Trans slipping
    I had the trans fluid flushed today and when I got my ride back both the front and the rear slips, the front tod indicator shows the wheels slipping but there noty and when I go from reverse to drive it hesitates and then slams into gear, Is it possible they did not put the right amount of tranny fluid back in or could there be some air in the system, the Dealer did the work so I assumed they new what they were doing, by the time I got home the dealer was closed so I thought someone could give me a heads up.
    01VX
    '01 Ironman
    I think when you fill it it needs to be running or you will be a couple quarts shy of full and cause what you are experiencing. Did you also change the filter? I think you should have that done when you change the fluid. not just flush and fill.
    Dec 2003
    99 white Ironman 0922
    AlaskaVX is right it might be filter. Also check fluid level while engine running and warm.
    Definitely check the level. Eng warm and running and on a level surface.
    Since flushing is supposed to relace the same amount of fluid that is removed, if it IS a fluid level problem I'd have to question whether you got a flush or just a drain and refill and customer hose job.
    1999, Ebony Black, VX ,1976
    if it was not doing it before ,then check the fluid level. if the filter was the problem it would have done it before. shawn
    1COOLVX
  1. Transmission Slipping
    By DeepSilentComplete in forum VX Troubleshooting...
    Last Post: 10/29/2012, 02:45 PM
  2. 1870 trans slipping code. Crap
    By MustangO4 in forum VX Troubleshooting...
    Last Post: 06/26/2012, 09:19 PM
  3. trans slipping
    By Vehi-Cross-Az in forum VX Troubleshooting...
    Last Post: 11/25/2011, 09:32 AM
  4. Transmission slipping
    By TRUSFJ40 in forum VX Troubleshooting...
    Last Post: 09/11/2011, 09:34 AM
  5. 1st gear slipping
    By Pete in forum VX Troubleshooting...
    Last Post: 12/08/2003, 05:14 PM
