Results 1 to 12 of 12
Thread: Rolling in Park?
    '01 Ironman
    Rolling in Park?
    Well I parked my VX at my buddies house with a slope of only 15-20* and by the time I was done eating my lunch I went out and it had rolled down the hill about 6 feet. Then to test that theory I went to another buddies house with a steeper driveway and parked, nothing happened, then I gave it a push from the front and it rolled back about a 1/4- 1/2 a tire rotation. Then we retried it in the same spot just a little higher and we then couldn't make it move?!! Now I know there is no way in hell park should let me roll back as far as it did at my first buddies house (6ft). What should I look for? This would be my tranny right? I only have 4,000 miles left on warranty and want to figure this one out quickly. Oh ya, when I rolled back in park I could press on the brakes to make me stop. I had my brakes checked 2 days ago and they told me 50% wear on the rear and 10-20% in the front.
    Thanks in advance,
    Alan
    2001 Black, Black, and more Black
    Do you have manual locking hubs installed on the front? DO you use the parking brake?
    -Daver
    -Daver
    '01 Ironman
    No and hardley ever. But while in park the tires should not move (after rolling back the little bit of "slack") correct? I was parking on very slick ice and instead of sliding down the hill it would roll.
    Sounds like a problem with the parking pawl in the trans.
    '99 Astral #1372
    Sounds like you need to adjust the trans shift lever. Maybe the transmission isn't making it all the way into park. Do you ever have problems putting it into drive, where you shift it and upon applying the gas, it "jumps" into gear?
    1999, Ebony Black, VX ,1976
    does it happen on a hill that is not slippery ? i have had it happen with the truck at work on slippery ice . if it does not do it on non slippery surface than it is normal. shawn
    1COOLVX
    2001 Proton VX #0662
    Why would you EVER turn your truck off without setting the parking brake. You're resting the entire weight of the vehicle on the transmission.
    Canadian VXer!
    '01 Ironman
    Why you ask? Because its cold in Alaska and I have had the e-brake stick already. Also I am not always parking on an incline (that's when I use the parking brake). I also put it in neutral until it settles then put it into park as not to put pressure on the trans.
    Zu4two, I have never had problems with it jumping into gear, but thanks for the suggestion.
    pschos2, if it does it on ice wouldn't it be more likely to do it on pavement? It's not sliding its ROLLING (tires move)
    SGT. Batguano, sounds logical to me. What would need to be done in order to fix this? New transmission or just new parking pawl?
    Feb 2003
    2001, Black, VX, 0781
    Manual says to always engage the parking brake and then shift into park. I've heard people complain about their parking brakes freezing up (cars other than the VX) but I've never had that happen on any vehicle of mine. Not necessarily Alaska weather, but spent a few years in Illinois where I regularly froze a certain part of my body off.
    because if you were to jack the rear of the car off the ground and turn one of the wheels ,the other wheel will turn in the opposite direction. if you try to turn them in the same direction they will not turn. so when you park on dry pavement the car will not move. if you park on ice it has the same effect as the jack and the wheels can turn in opposite directions causing the car to move. shawn
    You would need to drop the pan at the very least, which means supporting the trans and dropping the crossmember. Next, you have to know what to look for. It could possibly be a simple matter of the PARK selection not fully engaging, but it could also be a broken pawl. Know of a good local trans shop?
    My parking brake froze a couple times this winter in the Boston area.
    I still use it all the time, but I can see how it would be much more of a concern in Alaska.
    -Daver
  1. Opinions on low rolling resistance tires?
    By Noctis in forum VX Talk...
    Last Post: 02/04/2013, 09:26 AM
  2. To park or Not to Park -- or Sell
    By KeithVXlvr in forum VX Talk...
    Last Post: 06/19/2009, 02:39 PM
  3. Jurrassic Park?
    Last Post: 10/31/2008, 11:41 AM
  4. Rolling road day tomorrow
    By Greasemonkey in forum VX Talk...
    Last Post: 07/28/2008, 12:03 PM
  5. stopping things rolling around
    Last Post: 01/02/2007, 10:41 AM
