From what I understand(reading other treads), I can just "pop" the old one and slip on the new one.....true?
Draftsman of the dead
Uhhhhh... what?Am I being blonde (as usual) or did that statment just not make any sense? Pop what? Slip on a new one? Uhhhh... by the time you slip the new one on the damage is already done... that might be a bad thing... then again, if your not talking about a condom, nevermind what I said! lol Sorry... I have read the statment a few times and still have no clue.
Sorry... maybe be more specific.
TTYL!
Undergoing LS1 Coversion as we speak!
I'm assuming Jay meant the serpentine belt...
But kiddies, ALWAYS USE A CONDOM!!![]()
Maybe he means his treads?
Yes, the serpentine belt......silly boys.
All this popping and slipping ! Is it getting hot in here?;eekp;
From what I read, there is a tension spring and can be "moved" to slip a new belt on.....true?
No need to mess with the tension spring. All you do is lift the belt off the top pulleys with your bare hands to remove the old belt, then thread the new belt on following the diagram then lift it onto the top pulleys again with your bare hands.
NAVIGATOR
E Z E Nuff!![]()
It's allllll goooood!![]()
Thanks
You can't be serious. Is it really that easy???Originally posted by Navigator
I personally used a socket with rachet on the tensioner to release the spring-tension on the belt and removed it...reverse to install new belt. Easy.
Yep its that simple!!!Originally posted by kpaske
What I did also was draw a diagram, just in case I forgot how to rework it.(the instructions don't cover our Vehicle's application)
The Bantan's Relm
Gallery
Myspace Page
I found a HOWTO written by Randy where he recommends changing the timing belt, timing belt tensioner, water pump, serpentine belt, and radiator hoses all at the same time. Is all of this necessary at 90-100k miles, or is it overkill? The manual says the timing belt should be changed at 100k under normal use, but it doesn't mention any of these other items.
Not overkill at all. Tensioners & Water pumps on Isuzus have a tendency to fail at about 100K. Best to change out everything while you have access when changing Timing Belt.Originally posted by kpaske
