Results 1 to 12 of 12
Thread: Reducing oil consumption
    99, Ironman, 0909
    I've been fretting over this oil consumption issue. My VX just went over 60k and it was sucking about a quart every 1000 miles. I read the suggestions on this group and replaced my pcv valve for $11. Since then oil consumption is negligible. I don't know what a pcv valve does exactly, but I sure appreciate the suggestion and the apparant fix!
    Glad to hear your VX is back up and running at 100%.
    Dec 2003
    99 white Ironman 0922
    Congrats VXcaver.
    Thx for the solution, I wish Isuzu would be this creative and help solve their engine design problem by issuing recall or bulletin.
    PCV stands for (positive crankcase ventilation). It's purpose is to scavenge combustion gases that passed by the piston rings into the crankcase and it reintroduces them into the intake manifold where they will be part of regular controlled combustion. It does it in proportionate fashion, when engine load is low, ring blow by is low and intake manifold vacuum is high, valve is partially closed. When engine load is high, ring blow by is high, intake manifold vacuum is low then PCV fully opens. If PCV fails opened it will reduce idle quality and on some engines oil will be sucked into the manifold. From other hand if PCV fails closed or gets blocked combustion gases will condensate within engine block and will degrade oil.
    I would definitely check condition of plugs and check engine compression for high pressure caused by combustion chamber built up from oil that got siphoned through the engine and run cleaner through it.
    VX922
    Sep 2003
    1997 ,silver vehi-cross,0091
    hi
    whats a pcv valve???
    think i might need one
    Dec 2003
    Smile
    Lenny look up
    1999 silver 1346
    Ok i have the same problem about 1 quart every 1000 miles so i guess i should replace my pvc. but does anyone know what it looks like and where it is located and if its hard to change?
    thanks
    adam
    Feb 2004
    2001, Kaiser 1188
    Zadam-
    Check the "How-To" I posted for changing the PCV. It's got pictures to help you locate it.
    Formerly VxRaNgEr
    Sep 2003
    Smile
    Originally posted by VX922
    Lenny look up
    doh sorry it was a quick scan and i didnt read it properly
    wont do that again
    May 2003
    thanks
    adam
    http://www.vehicross.info/forums/sho...&threadid=3203
    1999 silver 1346
    Thanks
    I think i got my next project as soon as it gets nice out
    adam
    99, Ironman, 0909
    VX922 - Thanks for the description of the pcv valve. I had the idea that it was something like that!
    I'm not a mechanic, but in my opinion pcv valve replacement will probably only help in a few situations. Since it's such an inexpensive and easy to replace part, it just seems like a good thing to try.
    2001 Proton VX 0790
    Crankcase vac helps create ringseal. This is why some race engines will run vac pumps to pull high crank vac.
    I've seen some of you run your valve cover to a breather. I wouldn't.
    John C.
  1. Oil Consumption
    Last Post: 10/29/2014, 12:34 PM
  2. oil consumption
    Last Post: 05/13/2014, 10:43 AM
  3. oil consumption
    By GAMEON in forum VX Troubleshooting...
    Last Post: 12/20/2013, 08:14 AM
  4. EGR and PCV vs Oil Consumption
    By Jason in forum VX Troubleshooting...
    Last Post: 02/05/2012, 01:38 PM
  5. Oil Consumption
    By XCross69 in forum VX Talk...
    Last Post: 02/21/2004, 03:26 PM
