Hello Everyone.
My buggy is leaking a little bit of oil. I took it to a dealer who explained that in many cases the PCV valve connections and the throttle body has to be cleaned out. Apparently the carbon build up cloggs up the ventilation and causes the crankcase to over-pressure which in turn cause oil to go thru the seals.
Is this something anyone else has seen?
-Fred
