Results 1 to 15 of 19
Thread: supercharger question...
    99'/astral silver/vehicross
    hey guys,
    i did a search for supercharger, but there are like a billion results!
    can anyone refresh my memory on how much gain we get from the alpine in hp?
    also, for tone or anyone else:
    would you suggest (when i have the money) that it would be better to buy a new long block and the SC at the same time and just put the whole sha-bang in at one time, and all brand-new? i was thinking that might be better than throwing all that pressure on my o-rings and gaskets, especially with the number1 problem that seems common.
    and about the number1 problem:
    what do you guys think about installing a pre-oiler on the block? i think that may help alot with the number one cylinder. probably help tremendously with engine wear altogether.
    am i crazy?
    thanks guys,
    technocoy
    macintosh man
    wrong section...moderator
    can you please move this to the right spot. my mistake.
    thanks,
    technocoy
    ...ummm
    ok, thanks for the flood of responses, but i feel i didn't quite get what you meant.
    no one has any knowledge on this or feedback?
    Aug 2003
    2001,White,Rodeo Sport,
    Well if you really have the money(if you are thinking this you probably do) then what you can do is buy the long block, and the supercharger and do the following: upgrade all of the internals with maybe higher quality light weight components. Make it more efficient. Would allow for higher boost to be run on the blower and more power would be the result.Makes sense right? And after you are done throw that in to the engine bay and try to sell your current engine to cash out some of the investment.
    If I had the money and time, I would do somthing like this, but then again thats me and the benefits may be very slight for the investment.
    I believe it adds about 45 HP.
    It only has 4 lbs. of boost, so it's not likely to blow the heads off.
    If you've maintained it well, you should be able to just throw it on your current engine and keep an eye on it. While your driving with it you can get the project engine under way, just in case.
    The problem of insufficient oiling of #1 rod, or the inverted oil control ring induced failure is gonna happen if it's gonna happen.
    I'd agree that a properly installed pre-luber can only help, even if only at startup.
    thanks guys...
    appreciate the feedback.
    i was just thinking that the pre-oiler idea may be a good one, and didn't know if it had been brought up before.
    i hope to get the supercharger sometime towards the end of this year.
    for those of you who have it: do you feel a considerable difference between the 215hp and the 260 you have with the SC? i want to feel like it is definitely worth the 3000 smackers. i have heard people saying that you really feel it in the low-end. what about interstate and passing speeds?
    thanks guys, sorry to be a pest about it, it's just that it's alot of money, i want it to be worth the investment!
    peace,
    technocoy
    Actually, our engine (as it comes from Isuzu) can handle substantially more than the 4- pounds of boost IF an ECU modification can be made and an extra injector added. But the bigger weak link in the driveline is the tranny which cannot handle much more than the SC currently puts out. I am in the process of having my 4L30E rebuilt and beefed up as much as possible and will have to see what it is capable of.
    Please ask around as there are quite a few of us running them and most have not trouble letting you drive it - there is no comparison with a stock VX and is THE best mod I have done and enjoy it daily getting on the freeway, pushing through the twisties, or crawling over rocks.
    '99 SC Ebony #1961
    I have the 5psi pulley on mine and I feel the difference on the highway the most, it really is faster after 50ish it has no problem running to 100 now. I feel it was WELL worth the money.
    -Dave
    TEXNTEG Guest
    is the 4L30E a GM transmission?
    Yes. I believe it's a Borg-Warner product and is used in Cadillac Catera and BMW Z-3, Holden Commodore, Opel products, among others. Been posted previously. Try the "Search" button.
    http://www.gm.com/automotive/gmpower.../4l30_main.htm
    Tranny is made in Strasbourg, France by GM and used in several products as mentioned above. Borg-Warner makes the transfer case / TOD unit.
    -Dave
    what is the hp difference between the 4 psi pulley and the 5 psi pulley?
    Scott
    '99 SC Ebony #1961
    Another pound of boost, another 10-15 HP
    I've got 2 pulleys in stock....
    Feb 2004
    2001, SUPERCHARGED!
    Hey Tone, I thought you were going to drop me a line when those came in. I've been waiting months for all the pieces to be available, I guess you don't want my money.
    Draftsman of the dead
  1. Supercharger question
    By ScottinMA in forum VX Modifications...
    Last Post: 09/16/2014, 10:10 AM
  2. supercharger----what you think??
    By castigan in forum VX Troubleshooting...
    Last Post: 09/25/2007, 02:28 PM
  3. supercharger peeps question
    Last Post: 12/26/2006, 08:19 PM
  4. Question for the Supercharger Peeps
    By Ruflyf in forum VX Modifications...
    Last Post: 02/09/2006, 04:38 PM
  5. Supercharger Question (noise)
    By t2p in forum VX Modifications...
    Last Post: 06/09/2004, 04:00 PM
