Results 1 to 8 of 8
Thread: check engine light
    Sep 2003
    1997 ,silver vehi-cross,0091
    check engine light
    hi all
    i know i should search past posts sorry
    strange today on way to work driving normally, bling engine light came on erm? pulled over to check all and every thing seemed ok so went onto work engine light still on no problems in the way it drove, so at work took a lead off the battery for a couple of mins then put it back on, engine light has stayed off,
    any one else had this
    is there a common sensor that breaks down
    many thanks all
    Feb 2003
    good luck...could be anything from a short to intake to nothing...to MAF...to fuel cap not on tight enough...etc....
    Sep 2003
    thanks
    just read through past post very helpful
    many thanks
    Try to find someone who can read the trouble code next time.
    '99 Ebony Black VX, 0339
    Fuel cap not on tight will NOT cause a flashing CEL - flashing indicates a more severe problem like spark knock or misfire. Best to retrieve that code and be gentle when it is flashing if you must move it.
    1999,White,Ironman,0184
    I had an intermitent check engine light. car ran fine. it was an intake maniford gasket going bad. Replaced the gasket and it runs better than before. may not be your problem, but something else to consider.
    Sep 2003
    thanks
    2000,black,029
    A flashing light indicates a misfire above a certain percent that will cause cat damage. When I did misfire cals on the prowler we would cause a misfire and monitor the cat temps until they got to a point that would cause damage. The cal would then be set at this misfire percent. My wife's trooper just set a flashing light. Turned out to be the intake gasket. This will be the second one in a year. I monitored the scanner and the front two cylinders( one on each bank) were misfiring every time.
    Andy from Isuzu America
  1. first check engine light
  2. Check Engine Light
  3. Check Engine Light
  4. Check Engine Light...
