Results 1 to 15 of 16
Thread: Alarm/keyless Entry
    Jan 2004
    2000/green
    Alarm/keyless Entry
    I bought my 2000 a yr ago and didn't get a manuel or a keyless entry. I went to the dealer and said there is a light indicator on the dash but I wasn't sure what it was for. He looked and said he didn't see that the 2000 came with one. If it's not for that then what is it? It's on the dash located below the defrost button.
    Does anyone else know if they come with the keychain keyless entry and if so does it have a factory alarm?
    Dealer went ahead and ordered the keychain remote but He said they will have to program it according to the VIN.
    Not sure how they can program it if it doesn't have that installed.
    He said he would let me know when it's in but wasn't overly helpful otherwise.
    Thanks.
    Nov 2003
    1999,Victory White, Ironman, #0414
    Yes, they came with the keyless entry & the alarm system, and that red light is the security monitor. It flashes when armed or disarmed.
    :yesr:
    Dreamers of the day are dangerous people, for they
    dream their dreams with open eyes, and make them come true.
    Nov 2003
    Your's has an alarm if it has the light!
    I've found that when it come the VX dealers are dumb. They don't know crap about the standard features and when it comes to the alarm they're clueless. My alarm/keyless entry works but doesn't make a sound when I enable or disable it. There is a sound option to it but I couldn't make it work following the manual. I asked my dealership and they told me that none of them made a sound. Funny, at the time they had just gotton an Ironman in and it made a noise when I unlocked it to test drive it. Basically the bastards lied to me. I still haven't figured out how to get mine to beep when I use it, but I know the dealer is no help.
    You have an alarm, just don't expect the dealer to make it operate.
    Jan 2004
    2000/green
    Thanks for the help.
    Also to throw in the mix my VX has a salvaged title because it was stolen somewhere near Denver and driven to KC before they got the guy.
    It had no dmg and this is 50,000 miles later but I still bet the alarm is probably working if i can get the dealer to program that remote correctly.
    VX_PA's dilema
    Have you checked the alarm manual?
    downloads
    Here's the "buzzer" mode info:
    BUZZER OPERATION MODE
    The factory setting for the buzzer mode is buzzer ON. Selecting the buzzer OFF mode only affects the buzzer operation during remote arming & disarming.
    NOTE: Power loss to the system (e.g. due to a dead battery in the vehicle) has no effect on the operation of these or any other features.
    To change the buzzer operation mode, follow the steps below:
    1) Sit in the driver seat with all doors and the tailgate window closedl
    2)Press and release the remote control's top button once to lock the doors, then once again to inlock the driver door only.
    3) Open the driver door only.
    4) Insert the key into the ignition switch, and turn it to "ON" (not "ACC) 5 times (LOCK > ON > OFF > ON > OFF > ON > OFF > ON > OFF > ON) within a 10 second period.
    * The buzzer chirps once.
    * THe vehicle's marker lights and parking lights flash once.
    * THe status indicator LED will turn on for 30 seconds.
    -YOU MUST PERFORM THE NEXT STEPS WITHIN 30 SECONDS-
    5) Select the operating mode
    BUZZER OFF
    A) Close the driver door
    B) Turn the ignition switch to the "OFF" position. *
    * the buzzer chirps once.
    * the marker lights and parking lights flash once.
    BUZZER ON
    A) Close the driver door, then open and close it again.
    B) Turn the ignition switch to the "OFF" position *
    * The buzzer chirps twice.
    * The marker lights and parking lights flash twice.
    * If you do not turn the ignition key to "OFF", or exceed 30 seconds during the programming steps, the status indicator LED will turn off, and the operation mode will remain unchanged.
    Let us know if it works. It could be something else is wrong with your horn or electrical system.
    I Loved My Space Buggy
    keyless
    can i get this put on my 99? anyone know how much and how to go about adding it?
    Hotwheels™ toy come to life.
    www.doubleadesign.com
    the buzzer is under the hood by the brake fluid reservoir
    01 Proton VX.0851
    my alarm works just fine, but the armed LED
    01 Proton VX.0851
    my alarm works just fine, but the armed LED light never once came on
    Nov 2003
    Question
    Mine comes on and slowly flashes while the VX is locked...
    Dave:yesr:
    Nov 2003
    Originally posted by Nerfzooka
    VX_PA's dilema
    downloads
    [COLOR=blue]BUZZER OPERATION MODE
    I get to this point and no buzzer chirps. I tried twice and there is still no sound. Maybe my buzzer doesn't buzz anymore? Do they make VX viagra?? I'll try agian once it warms up around here. Thanks for the intructions Nerfzooka.
    Mar 2003
    In case you or anyone else here needs keyfobs or keyless entry module, I have one... just pulled it from my VX a few little bit ago. I will be installing my Clifford Matrix RSX3.5 during my rewire stage of my motor swap. Since my keyless entry system has already been partially cut out of the system, I decided I will wire around it if need be... I have the module, the wire harness plugs that go to it, and TWO key fobs... I assume that the fobs don't need to be reporgrammed to the module but could be wrong. Again, if you or anyone else here is interested... drop me an email at rreed17@kc.rr.com or post here... although email is more reliable for me... Lemme know.
    TTYL!
    Undergoing LS1 Coversion as we speak!
    Mar 2003
    Re: keyless
    Hmmm... how did I miss that when I was RIPPING wires out of the VX?! I'll have to go take a peak and see if mine is still there... probably not... but if it is... it will go with the keyless entry module and fobs. TTYL!
    Coach... aka Randy! (I often forget who I really am!)
    My 2000 Ironman VX!... Nitto Terra Grapplers 285/60/18's on stock 18" rims, Power Vault Muffler, Tone Monday's custom tow package, OME 912 Springs, custom audio/video/multimedia computer system in the works! Transformation to LS1 V-8 Power as we speak!
    My Webshots Gallery...
    2001 Black, Black, and more Black
    Re: keyless
    I'm pretty sure the alarm/keyless entry was a standard option, even in 99.
    If yours really doesn't have it, I recommend a after-market alarm instead, like a Clifford or Viper. Pretty much any of the DEI brands. http://www.directed.com/
    -Daver
    -Daver
    Mar 2003
    If you question whether or not your VX even has the keyless entry module in it, look up under the drivers side dash, to the left of the steering column... there will be two black boxes on brackets. The keyless entry box has three plugs on it, one plug has only one wire (white or light gray), the other plugs have 6-8 wires each... if that box isn't there... well... maybe they put it in a different place in 99... but doubt it.
    TTYL!
    Randy!
  1. Keyless entry
    By Arconcut2@yahoo.com in forum VX Troubleshooting...
    Last Post: 05/03/2016, 08:35 PM
  2. VX Keyless Entry?
    By shinkson in forum VX Talk...
    Last Post: 03/19/2011, 09:35 AM
  3. alarm, keyless entry.....again
    Last Post: 05/05/2006, 07:23 AM
  4. Keyless entry Fob
    By Sheik-YurBooty in forum VX Modifications...
    Last Post: 08/24/2003, 10:10 AM
  5. Alarm/Keyless entry
    By billh23 in forum VX Troubleshooting...
    Last Post: 08/18/2003, 03:56 PM
