View Poll Results: What # Octane gas do you use?
Voters
267. You may not vote on this poll
  • 87
    154 57.68%
  • 89
    46 17.23%
  • 93
    52 19.48%
  • Other, please specify in post.
    15 5.62%
Page 2 of 7 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 16 to 30 of 106
Thread: What Octane?
    Jun 2007
    2001, Proton
    according to studies
    not VX specific using gas with octane above revomended will do nether harm norimprovement. Using oil rather than recomended can cause engine failure. That being said I occasionally run 110 octane through me Jensen Healey and clean the carbs out.
    Carter Pewterschmidt
    1999,White,Ironman,0184
    BS on both! with the SC you can certainly use the higher octane, if it doesn't need it, it will be just wasted but no harm. And synthetic oil meets and/or exceeds all SAE specs. Plus it does not breakdown like conventional oil. The guys does not know what he's talking about.
    Jan 2004
    2001, Kaiser 1188
    Where to they FIND these service guys!? An octane rating is just how resistant a fuel is to compression detonation (you want the spark to ignite the fuel, not compression or else you get knocking). Higher octane is just more resistant to causing knocking. Ain't NOTHIN wrong with that. Usually, the higher the compression ratio, the higher the octane, but if you put higher octane in your engine its only going to run better and protect it better from pre-detonation/knocking. Now go back there and kick him square in the huevos!
    BTW...because of our elevation, Colorado's regular grade is 85.
    Friend: "So it's an SUV right?"
    Me: "It's kinda like the spork of the automotive world...you get all the benifits of a spoon, plus lots of the benefits of a fork."
    Friend: "Oh."
    He may not be totally wrong on the octane thing. I read somewhere that higher octane gas doesn't "burn" as efficiently in an engine that doesn't "need" it. What you need is a method to monitor your knock counts and up the octane until they stay at zero.
    2001foxfire0203
    Neighbor owns a gas station /He says Mid grade is the way to go.Has all the additives to keep injectors clean and octane is 89 .Can't tell the difference w/Premium 94 octane ,just a lighter wallet.
    '01 Ironman
    Thats crazy, it actually says 87 is the minimum for the VX in the manual. I have never heard of anything less than 87
    Nov 2003
    1999,Victory White, Ironman, #0414
    Usually use 90---since it's the highest available everywhere. I spoil my VX even if it does lighten the wallet (maybe needlessly).
    Dreamers of the day are dangerous people, for they
    dream their dreams with open eyes, and make them come true.
    Jan 2004
    2001, Kaiser 1188
    Hmmm....it appears you're right:
    http://www.koaa.com/features/investi...iew.asp?ID=251
    Looks like I'll be switching to 87!
    '01 Ironman
    If I was in Colorado I would start getting people together and get the "public outcry" that they say they need. As it is now up in AK we pay $1.63 for regular 87 octane, if you are paying more I would be ! I really can't see how everyone would be OK with this
    And I thought Spazz was just messing around saying 85, especially when he stated he got better performance out of it ;eekr;
    2001 Ebony 0177
    I've used 93 and Mobile1 since it was 11mi. old.Still purrs just fine thank you
    2000, Dragon Green, VX, 0720
    Testing
    Hotsauce -- you and I were thinking the same thing...
    I've actually run my VX (stock engine) through a test of 10 tankfuls of 87 and 10 tankfuls of 93. I do about 50% city driving and 50% highway (with offroading another 10% -- wait a minute...) and I found that my gas mileage did go up slightly with the higher octane (something along the order of about .5 mpg).
    My main goal in the test was to see if the higher octane was actually cheaper to run (to see if the better gas mileage would compensate for the higher price at the pump) and I found it really didn't.
    If I remember correctly when I did the test it worked out to about $.08 per mile on the 87 and about $.10 per mile on the 93.
    In terms of performance, I honestly haven't seen any performance dip or higher knock count on the 87.
    Rob Hawley
    Proud Papa of a 2000 Green Dragon #0720
    rlhawley@comcast.net
    Feb 2003
    1999, SILVER, VX, 1440
    About octane
    Sorry guys but i mix my gas for my vehicross
    Nov 2003
    Re: About octane
    Mix it?? What are you running??
    Octane Boost (104+)
    Turbo Blue
    Jet Fuel
    50/50 Mix
    Wow, that's some machine!!!
    ;eekp;
    Re: About octane
    Don't be sorry. many people mix different octanes to get a good "in between" for the money.
    VX King - the only one to talk so much about a VX NO one has ever seen....
  1. MPG Testing AR-5 + 93 Octane
    Last Post: 06/30/2014, 12:42 PM
  2. 100 Octane Gas
    Last Post: 08/25/2009, 11:29 AM
  3. 110 Octane?!!
    By Medman in forum VX Talk...
    Last Post: 04/11/2004, 01:34 PM
