Results 1 to 11 of 11
Thread: How much lift is needed to fit.....
Threaded View
    '01 Ironman
    I'm curious how much lift I would need to fit 33x12.5x16 TSL-SSR series tires on my Eagle alloy rims. Would 2.5"-3" be enough? How can I get an extra inch to inch and a half of lift if these won't fit with a lift: either 912 springs (2.5") or Calmini (3"). I have trimmed the front of the front fender already to fit my 31x11.5x16 but I don't really want to trim anything off of the back of the front wheel well. Can I even go 12.5" wide? If not I guess I will go with the 32x11.5x16's. The tires I have now stick out about an inch how it is on the same rim these are to be mounted on. Rim dimensions are below...
    FINISH: Polished
    PATTERN: 6 on 5.5
    OFFSET: -24 mm
    BSM: 4.50
    CAP: N/I
    LOAD: 3420 lbs.
    WEIGHT: 23 lbs.
    pic of tire:
    Thanks in advance,
    Alan
  1. 235/85 r16 - lift needed?
    By Dazed & Confused in forum VX Modifications...
    Last Post: 07/06/2014, 05:06 PM
  2. To lift or not to lift that is the question
    By CatFish in forum VX Talk...
    Last Post: 03/28/2012, 04:15 PM
  3. lift kit needed
    By codyman3487 in forum VX Modifications...
    Last Post: 03/18/2011, 12:51 AM
  4. Lift thread to end all lift threads
    By tbigity in forum VX Modifications...
    Last Post: 05/22/2007, 11:54 PM
  5. Help is needed
    Last Post: 01/25/2007, 04:44 PM
