Results 1 to 15 of 18
Thread: Problems with Calmini????
    Feb 2003
    Exclamation Problems with Calmini????
    how many of you have had or have problems with the Calmini springs sagging
    I have heard from a few who have...but Calmini denies this....
    I have some springs but never installed them. I do remember reading a post though, stating that the springs manage to pop out or something for some reason. Anyone recall this claim?
    99 Silver VX
    Yeah, they will sag after about 6 months of hard use....
    They did offer to replace mine but not with a taller spring.
    They do fall out also, but only if you run a longer shock than stock.
    ARB OMEs have had no such trouble as far as I know
    Allan
    99 VX on 36"ers
    Feb 2003
    not worried about the springs falling out...just wire them in place so under articulation they stay.
    as for OME's they do not give 3" of lift...right? but, I guess if the Calmini's keep sagging severely...and the OME's don't...then it would be better to have 2 1/4" lift that don't sag verses....3" lift springs that only last a few months then go to sh!&
    Oct 2003
    2000 Kaiser
    My impression was that OME's give 3 also. have a set in the garage i have yet to install.
    '01 Ironman
    curious
    Are the OME 912's springs and Calmini springs the same size? How about swapping the springs for the 912's? Just a thought...
    Are the springs really the only part that lifts it in the Calmini kit or are there spacers and whatnot that give you the extra 1/2-1"?
    Feb 2003
    OME 912's do not give 3" of lift...more like 2 1/4"
    Calmini is just springs for the lift in the rear...you crank your torsion bars for the lift in the front. Just need bump stop spacers in the rear or your tires will push up and rip out rivets bolts cladding, etc. But, in the front the stops are not needed
    but, I guess you could go with the 912's or 913's and then get a 1" spacer...they are available.
    99 Silver VX
    OME 919 will give around 4" lift on the VX
    on the trooper they lift 3+"
    Aug 2006
    1999, Astral, Vehicross, 1619
    Quote Originally Posted by BigMeatVX
    So I could go for the 919's and get the 4", but the front will only go up about three with the torsion crank. Is that right?
    Quote Originally Posted by CrnCnn
    Holy Old Thread Batman!
    That appears to be the word on the street. I don't think anyone has actually gotten a full 4" out of them, but close to it. With the torsion crank though, do the flip mod.
    Unless you do a front axle drop your CVs will be screaming for mercy with that much lift!
    Aug 2006
    Quote Originally Posted by Triathlete
    So for longevity, I would be better of with the 3 inch.
    Oct 2002
    2001, Ebony/Red, 0189
    Does the calmini give you more than cranking the bars in front, and does it keep the cv angles lower? I have mine cranked and the 912 springs and the front sits a bit lower. And can you just order the front lift if it gives you more?
    Feb 2003
    Calmini Lift
    1) Front Bump stop extensions
    2) Rear Bump stop Extensions
    3) Rear Coil Springs (sag after like 3 months)
    4) Front Shocks (not needed...just use stock)
    5) Rear Shocks (too soft)
    6) Rear Trac bar extension
    7) Rear center brake line
    8) New Cross member (not needed...is too soft anyway)
    they used to offer longer brake lines, but they realized these are not really needed
    and for the lift in the front...just crank your torsion bars to desired height
    Got OME 912s on mine measures 37-1/2" from ground to top of cladding arch. Supposedly a 2-1/2" lift. My tires are 30-1/2".
  1. Calmini lift kit problems
    Last Post: 04/11/2014, 06:05 PM
  2. Calmini lift
    By haggisgood in forum VX Modifications...
    Last Post: 01/15/2009, 11:39 AM
  3. Calmini
    By CrnCnn in forum VX Modifications...
    Last Post: 11/21/2006, 02:55 PM
  4. Calmini SAS kit
    By azskyrider in forum VX Talk...
    Last Post: 12/28/2005, 07:40 PM
  5. Calmini sways are G-O-O-D
    By hchen in forum VX Modifications...
    Last Post: 06/19/2003, 08:18 AM
