Just curious if anyone here has ever rebuilt an automatic transmission. I need to change the output shaft from my 4L60E transmission to a 4x4 output shaft. I have done SOME research and found that the swap doesn't require any subassemblies to be taken apart to do the swap. Of course, this would be the FIRST time I have ever taken a transmission apart and wanted to see if anyone had any experience or input on this. I have checked around to find that for a transmission shop to do the work, including a gasket kit but NOT the output shaft, the price is gonna be around $250. This is without any rebuilding of anything else... just the output shaft swap. I'm considering doing it myself... maybe even if I have to buy a manual for the thing ($20-$30). Whatayathink?!
TTYL!
The $250 price was just to crack the tranny open, change the output shaft and put a new gasket kit in. I am certain that if I was going for a complete rebuild it would cost much more. If he would completely rebuild it for that... I wouldn't even thing twice! Advance adaptors was one of my first stops on looking for the parts I needed. They basically told me that they couldnt help me. Rob (@adavanceadaptors.com) only suggested that I might be able to have an intermediate plate machined to adapt the stock VX adaptor plate to the 4L60E transmission. I am going to check with Chevrolet though first... the Colorado has a 4L60E transmission from what I understand... and the T-Case in there is under the name "Isuzu T150" and it looks suspiciously like the TOD unit. Maybe with some luck, the adaptor plate on that setup will work for me.
