Results 1 to 6 of 6
Thread: Front axle driven wheel?
    Does anyone know which wheel gets the torque on the front axle?
    Apr 2003
    1999 Astral Silver 1222
    Both, unless they are slipping in which case its the one with the least traction. It is an open diff. That reminds me... I wish I could afford an ARB unit... oh well
    Dec 2003
    89 Kawasaki Green Amigo
    yep the above post is right on.
    If you're wondering which one is more likely to break though, its the short one. Less shaft length to twist and absorb shock loads.
    Dallas
    WWW.STINKYFAB.COM
    Let me rephrase the question
    I agree the front is an open type.
    I associate open diffs and solid rear axles with one-wheel burnouts, because it tends to be the same wheel every time, due to the torque and lifting forces at work and the lack of countermeasures that a posi unit provides.
    I know that kind of slippage can be overcome with airbags or weight distribution. What I'd like to know is which wheel on the front of the VX is most likely to spin like in the burn-out example above. I'm theorizing that although front "wheel" lift is pretty much negated by the independent front suspension and the offset of the differential from center, the passenger(short) side "axle" would receive the "lifting" force due to pinion/ ring relationship. Agreed?
    Stink- Is that what you meant when you say break? As in break loose? Or do you mean physically break parts?
    Apr 2003
    For non rock crawler use a limited slip differential can also be used. It has some minor negative effects, but you would never have to worry about slippage all the way around. Kind of like the Subaru Sti locked all 4 ways
    Why do you say "non rockcrawler" use. Isn't the purpose of the posi to transfer power to the wheel that's slipping?
  1. front axle leak
    Last Post: 02/17/2015, 09:57 AM
  2. front axle conversion
    Last Post: 06/05/2012, 08:39 PM
  3. front axle problems
    By bigkoala1 in forum VX Troubleshooting...
    Last Post: 01/24/2011, 02:43 AM
  4. Front Axle Drop Help
    By bobmumgaard in forum VX Troubleshooting...
    Last Post: 12/24/2005, 10:19 PM
  5. front axle mouting brackets?
    Last Post: 02/05/2004, 07:45 PM
