Results 1 to 5 of 5
Thread: Headlight Lens ? for Carlymac
    Carlymac posted this on the other board...
    I had both lenses replaced under warrantee. The fell victim to the little scratches. anyhow the Lens part number is:
    Lens,Lamp right/8-97212-447-0 $18.02
    left/ 8-97212-448-0 $18.02
    These are the lenses only, so the old lenses have to be removed from the assymbly and the new lenses glued back on. the whole assymbly costs $299.34
    Question is, What type of adhessive was used to glue the lens back on? Did you do this yourself or did the shop do it. Mine are scrathed and $40 sounds much better than $500. I know there is a post on this board that tells how to take the headlight assembly apart!
    To seal, you might try a small bead of black RTV or silicone. They won't be easy to re-open after that, though.
    '99,victory white(ironman),VX,#0278
    Lightbulb Answer for Triathlete
    I had my dealer replace the lenses. It was a warranty issue so I dont know how they cracked open the old assymblies. There is evedence of some sort of clear glue (silicon looking) around the lens/housing joints. I remember Ron posting about tring to open the headlamp assymbly but, I don't remeber seeing the outcome. The part numbers were ascertained through a parts list I bought off ebay...so far the part #'s have been accurate. Sorry I couldn't give a step by step but maybe Ron has the answer you seek...carl
    carlymac '99 IRONMAN , #0278, Hendersonville, Tn.
    Feb 2003
    2001, Black, VX, 0781
    Does that parts list show seperate part numbers for the equivalent lenses for the rear light assemblies? I'm doubting it, but just in case, I figured I'd ask.
    Unhappy
    Nope, the taillamp assymbly is sold as a unit...sorry here's the part numbers anyway.
    right taillamp assy...part# 8-97211-375-2...$158.85
    left taillamp assy...part# 8-97211-376-2...$158.85
    right taillamp gasket...part# 8-97211-801-0...$124.95
    left taillamp gasket...part# 8-97211-802-0...$124.95
  1. headlight polycarbonate lens
    By angeno in forum VX Talk...
    Last Post: 07/27/2012, 08:00 AM
  2. A VX through A Lomo Lens
    Last Post: 04/03/2012, 07:11 AM
  3. Thanks, carlymac, for the lock/alarm antenna mod
    By workmeistr in forum VX Modifications...
    Last Post: 11/29/2008, 01:12 PM
  4. Headlight Lens Restoration
    By UtahVXer in forum VX Talk...
    Last Post: 10/14/2005, 07:18 AM
  5. Headlight lens scratches
    By MiamiVX in forum VX Modifications...
    Last Post: 08/25/2003, 12:43 AM
