Results 1 to 3 of 3
Thread: stock cd player
    1999, Ebony Black, VX ,1976
    stock cd player
    my cd player stopped working this morning.the err3 message keeps showing .so i just took the cd player out and what did i find ,the idiots that installed it did not remove one of the clamping screws that hold the insides in place til it is installed. there is a label attached that says " ALWAYS REMOVE THIS CLAMPING SCREW BEFORE INSTALLATION ! there is even a picture that shows where the screws are .it is actually attached to the one they did not remove. there are three of them .two of them you have to remove to install it the other is in the back.with this screw still in it beats itself to death.anyone that has removed a bad cd player was there a red screw still in the back? shawn
    1COOLVX
    Dec 2002
    '01 Ironman
    I WILL TAKE MINE OUT TONIGHT AND GET BACK TO YOU TOMMOROW
    i thought there might be a connection with the screw not being removed and all the failures of the stock cd changer. i know this is why mine failed. if this is the case then others can benefit from checking to see if all three screws were removed.so if anyone has removed there stock unit please check to see if there is a red screw in the back. shawn
  1. rebuilt cd player
    By gletom in forum VX Talk...
    Last Post: 08/30/2016, 01:44 AM
  2. Stock tires on wider than stock rims?
    By Y33TREKker in forum Wheels and Tires
    Last Post: 07/20/2013, 12:33 AM
  3. What cd player/speakers??
    Last Post: 12/18/2008, 08:13 PM
  4. Stock CD player song repeat
    By rogue1313 in forum VX Talk...
    Last Post: 02/12/2005, 11:31 AM
  5. CD player
    By Lease-V-cross in forum VX Troubleshooting...
    Last Post: 12/05/2003, 06:03 PM
