I'm getting ready for a 15,000 mile check up at a Local Isuzu Dealer. I'm mostly concerned in getting the transfer and diff fluids changed. I'm guessing they also go over/adjust engine settings, tighten loose bolts, etc. How long should I expect this to take? one, two, or more days? About how much should it costs? Worth it? At least one time? To see what kind of a job they will do?
Just looking for feed back from others who have had this checkup. I've read some horror stories. I'm in the Louisville, KY area and I think there is only one other VX around. So, the dealer will probably be a little green.
The only problem I've had is the rubber around the headlights and I just glued it back on.
