Results 1 to 4 of 4
Thread: Kenne Bell Boost-A-Pump
    '99 SC Ebony #1961
    Question Kenne Bell Boost-A-Pump
    Anybody know anything on this? Think I might try it for our Superchargers... looks like it is $199
    http://www.kennebell.net/accessories...boostapump.htm
    http://www.corral.net/tech/powerplant/tfue.htm
    This guy has some Dyno stuff with it...
    http://www.gadgetonline.com/dyno.htm
    -Dave
    Sure,
    It evolved from a Buick Grand National mod. It basically increases the voltage to the fuel pump. The two tricks before this involved running a #12 or 10 gauge wire to the fuel pump using the factory fuel pump feed wire to switch the new feed through a relay. This overcomes the voltage drop or loss that results from running smaller factory wires over long distances (from the very front to the very rear of vehicle) when using D.C. voltages (also a reason why your household power is A.C.) The other trick involved placing a 9 Volt battery in series with the pump feed wire to increase the voltage.
    99 Silver VX
    This would work great for those that are running more boost , like 5-8psi
    2000, Kaizer, 0500
    Alln, been trying to contact you
    Please e-mail or "personal message" me about the hitch. Thanks.
    Aric - MI VX
  1. Q: for BOOST jockeys
    Last Post: 11/26/2005, 09:41 AM
  2. SC boost gauge
    By frankie100 in forum VX Modifications...
    Last Post: 11/10/2005, 01:32 PM
  3. steering boost
    Last Post: 12/18/2004, 07:55 PM
  4. how to boost horsepower
    By Randy Floyd in forum VX Modifications...
    Last Post: 05/16/2003, 02:42 PM
  5. Bell's Magazine scans...
    By Cyrk in forum VX Modifications...
    Last Post: 05/02/2003, 07:41 AM
