Results 1 to 9 of 9
Thread: Oil in my INTAKE?! WTF?!
    Mar 2003
    As you know, I have been carefully dissassembling my motor... one piece at a time with my plans to install a different motor... I was looking at things today and realized that there are puddles of oil in my intake manifold! WTF is up with that? I mean, I see NO reason for oil to be in there... HOW does this happen? Am I wrong to think that this isn't normal? If not, its really gonna piss me off that the warranty company refused to even look at the damn thing... not that I want their crappy motor in there... just pisses me off. Whatayathink?!
    TTYL!
    Coach... aka Randy! (I often forget who I really am!)
    My 2000 Ironman VX!... Nitto Terra Grapplers 285/60/18's on stock 18" rims, Power Vault Muffler, Tone Monday's custom tow package, OME 912 Springs, custom audio/video/multimedia computer system in the works! Transformation to LS1 V-8 Power as we speak!
    My Webshots Gallery...
    Jan 2004
    got too many to list
    Rings, valves, valve guides etc can cause oil to be blown back into the intake manifold, I've seen that on another blown VX engine.
    There's a possibility of oil coming in through the pcv line or valve cover breather line. Did you have an oilable air filter on it?
    1999, ASTRAL
    Lightbulb Bad PCV perhaps...
    ...A failure of the PCV can cause an oil backup into the intake
    The PCV is a small often over looked device that is essential in reduction of emmisions and fuel economy.
    NAVIGATOR
    Apr 2003
    1999 Astral Silver 1222
    Inless something else is wrong, it is from the PCV valve. This is the same reason you can buy catch cans that remove most of that gunk. Its part of the wonderful emission system! It doesnt require a failure to do so- it is just from the vapor and gasses from the engine
    2000, Black, VX, 0021
    i would say it is from the pvc ... but was caused by the rod getting hot from the knock/hammering on the crank. I have seen rods turn blue and smoke any oil around that area. the entire crank case has oil on it but that one rod is dry because of the extreme heat.
    so it probably smoked some oil and the pvc system could not keep up with all the oil/smoke and it puddled in the intake.
    Anthony
    Mar 2003
    Thanks for the input guys... good explanation... I hope to get the motor out today... but not sure I care to pop it open anytime soon. Once the motor is out, I need to roll her out and clean the garage floor.. don't like laying in dust, dirt, rust and vehicular bodily fluids... later on when I get a chance... I'll pop it open and post some pictures. Anyway... thanks again.
    Randy!
    Dec 2003
    99 white Ironman 0922
    What is the possibility of lover part of the intake gasket leak? That would suck oil into intake.
    Mar 2003
    Nope... the only place the lower intake touches the motor is at the intake ports of the heads... not likely to get oil in that way... I have pictures of the intake in my "Phase I" post (will be posted next... so check it out...) Anyway... looks like a lot of oil has been in there for quite awhile... its actually kinda sludged on there. Aynway... check it out... BTW VX922... you kinda disappeared... I hope you stick around for this conversion I am doing... I'm sure we can talk shop along the way.
    TTYL!
  1. Pro/Con of Air intake Kit
    By marximus in forum VX Talk...
    Last Post: 02/27/2006, 07:24 AM
  2. SC intake?
    Last Post: 12/09/2003, 10:22 AM
  3. intake
    By MZ-N10 in forum VX Talk...
    Last Post: 12/08/2003, 09:13 AM
  4. Air Intake
    By grvcmike in forum VX Talk...
    Last Post: 03/25/2003, 02:49 AM
  5. Intake Bs
    By Cyrk in forum VX Talk...
    Last Post: 10/30/2002, 01:17 AM
