Results 1 to 6 of 6
Thread: Tensioner assembly
    '01 Proton #
    Tensioner assembly
    Well I'm in the middle of trying to change my timing belt and can't get the serpentine belt tensioner assembly off. The manual says there are two bolts holding it on, but it won't budge.
    Anybody have any experience here?
    Randy
    Happy Flying!
    Randy
    As posted previously, you don't need to remove the tensioner to remove the belt. Just grab and tug it and slip it off a pulley, then there should be enough slack to remove it. Installation should be in reverse order. If that doesn't do it, try putting a socket and ratchet on the tensioner pulley nut and turn the nut as you would to tighten (clockwise) . That should? relieve the tension.
    '01 Proton #
    I'm replacing the timing belt, not the serpentine belt. The tensioner assembly needs to come off so that I can remove the timing belt housing pieces. The timing belt is under those three housing pieces. Understand the belt I'm referring to runs the overhead cams in timing with the crankshaft. Not the belt that drives, alternator, power steering, AC, etc.
    By the way, while at it, I am also replacing the serpentine belt.
    Update.... I found that an allen bolt goes through the center of the tensioner. I got it off!
    Randy
    1999 White Ironman 0408
    Randy,
    Could you please share with us details on how you did it once you get it replaced? Thanks in advance
    May 2003
    '99 Astral #1613
    Wow, just noticed you two are from Jupiter and Coral Springs... when we get the next meet rescheduled at Joe's place, by all means drop by if you can - glad to see the Florida bunch growing! :-)
    It's quite embarrasing to admit I knew about all the last meetings but I couldn't attend any for different reasons...
    As far as I know, there are many more VXers in South Florida than those showing their face here.
  1. Best timing belt,water pump,tensioner etc...kit to get
    By bigblock8396375 in forum VX Talk...
    Last Post: 04/07/2011, 11:26 AM
  2. Goodyear belt tensioner part number
    By VXNIT in forum VX Talk...
    Last Post: 10/06/2010, 08:05 AM
  3. Dead tensioner
    Last Post: 11/21/2007, 01:49 PM
  4. Serpentine Belt Tensioner removal
    By Maugan_VX in forum VX Troubleshooting...
    Last Post: 08/22/2007, 06:23 AM
  5. Belt tensioner
    By scarpezio in forum VX Troubleshooting...
    Last Post: 02/07/2007, 01:22 PM
