Have been getting a slight ticking that appears to be coming from the bottom end, as its more eveident from the front DS wheelweel. Thought it might be lifters but the top end sounds fine. Its interremittent, oil level is full, Im running synthetic. It appears to come and go based on rev, and it is def a cause for concern. Anyone ever had bearings go bad? What does that sound like?
When you rev the motor, the ticking goes faster so its def an internal issue.
Bill
