Results 1 to 15 of 15
Thread: Fuel Pump, Car Stalls at Idle
    Jun 2019
    2001 Silver VX 0492
    I have heard about bad EGR/lines causing these issues. It'll definitely be one of the first things I try.
    Here are the CEL codes that I got:
    P0137: Oxygen Sensor Circuit Low Voltage Bank 1 Sensor 2
    P0157: Oxygen Sensor Circuit Low Voltage Bank 2 Sensor 2
    P0171: Bank 1 System Too Lean
    P1171: Fuel System Lean During Acceleration
    P0174: Bank 2 System Too Lean
    Honestly, before I try anything I'm going to go ahead and reinstall my old injectors to see if maybe the new injectors are the problem. The car only started acting this way after I swapped out the injectors so maybe that will fix the issue. Hopefully will have an update by Saturday night.
    Oct 2003
    2001, Foxfire VX,
    What was the final solution to this? Did putting back the old injectors solve it?
    Quote Originally Posted by Vehi MK 11 View Post
    I'm getting the 3 codes below on my '01 Foxfire. (90,454 miles)
    P0137: 02 Sensor Circuit Low voltage Bank 1 Sensor 2
    P0157: 02 Sensor Circuit Low voltage Bank 2 Sensor 2
    P1171: Primary Fuel Pump Insufficient/No Fuel Flow
    I've replaced both aft 02 sensors and cleared codes, only to have all 3 return. Don't want to rush replacing the cats just yet but the deadline for emissions testing is coming up and I'm wondering if a lean condition (P1171) can CAUSE the downstream sensor codes? (seems unlikely that both would go bad at the same time.)
    She starts, runs and accelerates fine. Visited a local muffler shop this morning and explained the scenario. The owner adamantly stated aftermarket 02 sensors are garbage, and that they must be OEM for this vehicle. (but I got the exact same codes as the original after the swapping them out.) I suspect there are different codes for NO communication with the computer vs. reporting LOW voltage, but I'm no expert. I'm going to change the fuel filter first and clear codes again to see if there's any change. If not, checking fuel pressure will be next. TIA for any other advice or suggestions.
    Oct 2014
    1999, Victory White, Ironman, 1567, 1999, Astral Silver(Painted Green Mica), Vehicross, 1454
    did your issue get resolved? Soonds like an intermittant fuel pump issue
  1. Fuel pump inoperative
    By alleycat in forum VX Troubleshooting...
    Last Post: 09/27/2019, 09:17 AM
  2. Possible fuel pump failure?
    By logman in forum VX Troubleshooting...
    Last Post: 03/29/2017, 12:10 PM
  3. Fuel pump replace??
    By VehiTONY in forum VX Troubleshooting...
    Last Post: 12/16/2015, 12:12 PM
  4. Fuel Pump Probs
    Last Post: 11/10/2004, 06:28 PM
