AC issue as above and the fix...Ok so after many, many, MANY hours spent on the overheating issue, it seems to have been caused by having too much freon in the system, causing the condenser to run hot & thereby causing a hotter engine compartment. After taking freon out to where the pressure was correct, the overheating issue has now stopped. Turns out, a faulty gauge was showing that there was not enough freon in the system. Adding freon caused too much pressure & made the condenser work harder than necessary & run hot. I just can't believe it's not overheating anymore!!!!!! 😊😊😊
