It looks like my fuel tank is rusting bad and starting to fail. It leaks fuel and needs to be replaced. Does anyone know if a Trooper tank will fit onto the VX? What are the possible options for replacing?
 New Member
						New Member
 New Member
						New Member
						UPDATE: The Trooper fuel tanks will crossover to the VX. I picked one up from a salvage yard here in Salt Lake City last week for $60! Score!!!
Sweet!
 'Zoid
						'Zoid
						How did the swap go? Did the fuel pump match ? Did you use the pump from the donor tank? Did the filler connection line up? Is the donor tank the same size/volume?
