So I had to take my drivers side door off to fix it's alignment, when I reinstalled back on, I plugged in the harnesses and buttoned everything up. When I went to use the key fob for the first time to lock the doors the locks wouldn't go down and the alarm made a straight tone for about 5 seconds, it makes the same tone when I push either button on the key fob, also, the door locks work on the inside door panel. Am I missing a reset of something after I unplugged and plugged in the two harness wires to the door?
