Results 1 to 7 of 7
Thread: Shifter Linkage
    Mar 2015
    Thanked: 34
    Shifter Linkage
    Been having a bit of trouble getting the shift lock button to depress on the shifter, after stepping on the brake and attempting to move the gear-shift out of park. Anyone experienced this? Any idea what may be causing this?
    Thanks!
    Jun 2016
    99' black, 01' baby poop yellow, 01 Toad green
    Thanked: 12
    99% of the time it's just the brake light switch at the brake peddle..
    They seem to stick more when it's cold out. Just replace it rather than clean..
    If your stuck undo or jump, the wires ( connector ) and that will get you out of park. Sorry I forget which..
    Mar 2015
    Thanked: 34
    Thanks for the response. I did notice it stuck more in the cold this morning, and seemed to work fine this afternoon. Any idea on where I buy this part? I'm not exactly sure what I'm looking for.
    Thanked: 29
    Thanked: 29
    Quote Originally Posted by ipd View Post
    Video is a VX.
    Part is the brake light switch and is available at most auto parts stores.
    2000, Ebony, VX, 0370
    Thanked: 12
    It's been a LLLOOOOONNNNG time, but another member had an issue with this in the past and it ended up being something in the center console. I would have to dig back through past threads, but if the brake light switch doesn't solve your problem I believe there is another switch of some kind in the center console near the shifter that allows the shift lock button to be pressed in.
    Feb 2019
    1999 silver 1085
    I have the opposite problem with mine. Onve it is out of park, I can shift it into anything from any gear. Bothers me only when I think - what if it gets bumped into reverse while driving. Then I slip back into happy mode because I drive something so fun!
  1. Is there an easy trans linkage adjustment for this?
    By 89Vette in forum VX Troubleshooting...
    Last Post: 08/13/2013, 07:30 AM
  2. Shifter VXs
    By Bieredalsace in forum VX Talk...
    Last Post: 10/17/2007, 03:27 PM
  3. Sway bar linkage? (need to replace)
    By xdfarrx in forum VX Troubleshooting...
    Last Post: 07/14/2007, 06:04 AM
  4. shifter mods
    Last Post: 06/12/2006, 05:49 PM
  5. shifter
    Last Post: 12/12/2004, 09:50 AM
