Results 1 to 4 of 4
Thread: Need caliper info
    '01 Proton 1416
    Need caliper info
    Hey Guys,
    I'll try to be brief....
    Brakes were grinding, took it to local place I've used a lot, they said I needed calipers as part of repair, they replaced calipers with whatever came up on their computer as stock replacement.
    Everything was fine, until I went to switch from my Duelers on the stock 18" rims to my BFG MT "winter tires" that are on 15s. I've done this every year for probably 15 years. Apparently, the replacement calipers are much larger than stock, because my 15s won't go on. The shop is trying to find smaller calipers but they don't seem to be making any progress.
    Can anyone recommend a caliper, or have any thoughts?
    I'd rather not spend $2,500 on bigger rims and new BFGs just because my shop can't find smaller calipers.
    Thanks all,
    Brian
    aka BBVX
    '01 Proton 1416
    Thanked: 29
    You could do OEM used from a salvage...on the FB group hit up Dan Danlister...he buys and parts out VXs that are beyond repair.
    Jun 2016
    99' black, 01' baby poop yellow, 01 Toad green
    Thanked: 12
    If you still have your old ones, just rebuild them. It's very simple. Emory cloth, O-ring, boot.
    '01 Proton 1416
    Thanks guys,
    the shop is actually trying to locate the old ones.
    I'll keep you posted
  1. Compressing caliper pistons
    By Allison3371 in forum VX Troubleshooting...
    Last Post: 12/14/2012, 06:47 AM
  2. caliper covers
    By habs10 in forum VX Talk...
    Last Post: 09/01/2010, 06:51 AM
  3. Stuck caliper, replace or can I fix?
    By VehiX in forum VX Troubleshooting...
    Last Post: 12/02/2009, 11:36 AM
  4. Caliper Mounting Bracket/Slide Pin
    Last Post: 11/28/2006, 07:01 AM
  5. Brake Caliper Lock Washers
    By Jolly Roger VX'er in forum General Tips...
    Last Post: 02/20/2005, 05:30 PM
