Hi,
do you guys know how to install child car seat in VX 99? There is no support for child seat.
Please help.
Thank you
 New Member
						New Member
						Hi,
Please help.
Thank you
What i did for my two car seats was replace the luggage tie downs in the rear area with D style ones . I then attached a 1000lb ratchet strap to the d ring and then passed it around the seat, through the back of the car seat and then to the d ring again. make sure you start ratcheting while its a bit loose so u get a few wraps around the strap so it doesnt slip. Then take the headrest strap back to the same point. The seatbelt is too far forward to secure the car seat tightly but install it in the normal way in addition to the ratchet strap as additional support. Hop that helps
