Results 1 to 8 of 8
Thread: Fuel line hose leak... (engine/firewall)
    Mar 2018
    1999 Iron Man 1536
    I have a rotted fuel line hose... Leaks up between the right hose ring clamp on injectors pipe and firewall... passenger side... May be return line hose?
    I cannot yet, find the other “lower” end of hose to remove and replace hose...
    Anyone know where the other end of hose is located and how to access?
    Thanks
    Robert
    Mar 2018
    1999 Iron Man 1536
    Have researched more... I believe the passenger side is the return hose fuel line... Still cannot find both ends of failed hose...
    Jun 2016
    01 Toad green
    Thanked: 12
    I'm pretty sure there is both the intake and return line. It has a soft W clamp that bolts to the back of the head. Going off memory they both are very short to the hard line and then back to rubber as it goes down into a shield along the tranny. IF you get the bolt out of the head replacing the hose will be a royal pain with the intake on. BE SURE TO RE-INSTALL THE BOLT or the hose will crack soon and leak again. I just up loaded pictures of it in my gallery..
    Jun 2016
    01 Toad green
    Thanked: 12
    Had to go look.. Sorry it is dark here
    Jun 2016
    01 Toad green
    Thanked: 12
    The only method that I'm aware of, is to remove the intake. (you probably need new intake gaskets anyway) Be sure the line(s) you use as replacements are rated for fuel injection use.
    Jun 2016
    01 Toad green
    Thanked: 12
    I was thinking maybe, just maybe if you pull the hood, pull the top half of the intake and what ever else in the way, take the front wheels off and lower and by crawling around on it like a high school wrestler trying to pin, there might be a chance.
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    Be careful when buying a new intake gasket. I went through 3 of them before the parts store got me the correct one. The 3.2 Upper Gasket is the same as the 3.5, but thinner. I popped two of them. Once we figured out there was a difference in the computer I tried the thicker one and haven't had a problem since. If nothing else have them pull a couple of different ones and open the boxes and just choose the thicker one.
  1. Fuel line problems
    By ND92 in forum VX Talk...
    Last Post: 09/09/2017, 10:34 AM
  2. Fuel line location - engine replacement
    By hootietang in forum VX Troubleshooting...
    Last Post: 06/23/2016, 03:41 PM
  3. severe leak metal transmission cooling line
    By bigevil in forum VX Troubleshooting...
    Last Post: 10/11/2014, 11:51 PM
  4. Transmission cooling line leak
    By Autor in forum General Tips...
    Last Post: 08/15/2013, 12:30 PM
  5. fuel pressure regulator, missing hose
    By SEBACOQUI in forum VX Troubleshooting...
    Last Post: 04/08/2013, 02:04 PM
