step 1: put a piece of masking tape above the blade to mark the current position of the blade.
step 2: Remove rubber covers via flat head screw driver shimmy.
step 3: Remove bolts
--drivers side is easiest to remove with the hood open
--passenger side is easiest to remove with the hood closed
step 4:remove wipers
--push down on the spring joint while lifting up
step 5: remove blades
step 6:sand down wipers
step 7: spray paint with rustoleum flat black
--let dry
step 8: reverse steps 4, 3, 2, 1
NOTE: the drivers side wiper is shorter than the passenger side.
