Results 1 to 7 of 7
Thread: Turn blinkers W/ LED-- need a resistor
    Mar 2015
    I've installed LED's pretty much everywhere on my VX. The blinker cycles very rapidly now. It doesn't bother me too much, but it does seem to annoy some people. Anyone have a plug/play fix for this? I really don't want to have to splice a resistor pack into the wiring if I can help it. I was looking more for something that plugs between the bulb and the wiring harness.
    Thanks in advance!
    There is a resistor you can just plug in under the driver side dash. It is a PITA to get to unless you have infant hands and toothpick arms.
    And sry, did this so long ago that I have no info on the part# you need, but, something similar to https://www.superbrightleds.com/more...asher/781/835/ .
    Mar 2015
    Interesting. I was really hoping to avoid having to use something like these:
    https://www.amazon.com/TOMALL-Resist...+load+resistor
    I haven't messed with the blinker assembly at all. Does this part you listed replace it?
    Yep, its plug and play. No splicing necessary. Just a module that you can plug in. Again, not sure of the part# though. IIRC, it is a 3 prong and MAY BE universal to most JP cars. Make sure you get one that handles turn signals, not just your hazards. I remember folks here making that mistake lot on here a while back.
    Dec 2013
    1999 Astral Silver 0291, 2000 Kaiser 0419
    Mar 2015
    https://www.ebay.com/itm/3-Pin-CF13-...97.m4902.l9144
    This is what I got. Hope it works. It looks to be the same part number as was mentioned in another thread on here.
    Quote Originally Posted by ipd View Post
  1. IAT Sensor - Resistor Mod
    Last Post: 06/13/2013, 08:56 PM
  2. A/C Blower Fan Resistor
    By Sean Rogers in forum VX Talk...
    Last Post: 12/08/2008, 06:16 AM
  3. heater resistor
    By froggg in forum VX Troubleshooting...
    Last Post: 02/22/2008, 12:06 PM
  4. The Resistor Nemesis
    By -wadestock- in forum VX Troubleshooting...
    Last Post: 12/08/2005, 12:49 PM
  5. Blinkers not working......
    By SPAZZ in forum VX Talk...
    Last Post: 01/11/2004, 07:06 PM
