Do as area 51 said (check the fuse first) and for a temporary fix (and kind of upgrade/mod) would be to put a switch on the TOD wire, which I believe is the only blue wire under the passenger seat? I think some people said it had silver or white stripe? Do a search on TOD disconnect and you will find the info. Jay (boarzhead) has been driving with it turned off for over a month now and he hasn't had any problems, even in the snow. Hope this helps
Alan
