Quote Originally Posted by Malibu_Robert View Post
Sorry to hear about your transmission, Maddawg. Thats a real bummer. Did you perform regular maintenace on the tranny? Are you sure you are not checking the level when it is too hot?
Thanks Malibu. Yes as a matter of fact I had the tranny serviced last year. I only put a couple thousand easy miles on it a year. I think you are overly worried about the trans temp, 90-135 degrees F is a wide range. I would just use the IR temp gun to sense the temp. Thanks for the comments, much obliged!
