Results 1 to 3 of 3
Thread: Power steering and Idle?
    Astral Silver - 1131
    My VXX has been giving me idle pains since last year.
    It will rev high during idle and during P and N. Not consistently. Now more than less.
    At first I thought it was my MAF, TPS, and IAC. Replaced them all, returned crom Cold air intake to stock air box. Rplaced PCV. Cleaned EGR. Changed Belt
    It was good for a week.
    Took it to a shop. The mechanic diconnected a high rev powersteering sensor (?) and it was fine again.
    But. No first gear power when engine is cool. loses power on turns.
    Today the high revving is back. Mechanic told me my PS has a bit of play...
    Does this sound right?
    Opinions please.
    Thank you.
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    I had the same issue. Chased it for months (Link to build thread). I unplugged the power steering pump sensor wire and that fixed it. Well, it worked for me I should say.
    You have some interesting things going on.
    The High Idle Issue:
    You said you clean the EGR, did you remove the intake manifold? If so, there are two intake gaskets that fit, but only one works. The one for the 3.2L engine is the same, but thinner material. This can cause it to fail. I went through of two of those in a month before I figured it out. The one for the 3.5 has a much thicker upper gasket.
    You can check for intake gasket leaks by spraying carb cleaner around the intake and see if the engine revs.
    Power Steering pump:
    Does the pump have play? Or the steering? If it is the steering, that is just an adjustment screw. If it is the pump, sounds like it is time for a new one.
    From everything you have said, it sounds very much like you have more than one issue at the same time. The high idle and low power are probably separate items to be repaired.
    Good luck!
    Oct 2012
    1999, Ebony 1727
    I agree with Thelgord about the intake gaskets. I changed absolutely everything that anybody mentions on this forum. And everything worked, for a while...
    After I did the intake gaskets it has idled perfectly for 2 years so far.
    It's time to give it up and replace the manifold gaskets.
  1. Power steering lines
    By glenngw3 in forum VX Troubleshooting...
    Last Post: 03/24/2014, 07:31 AM
  2. Power Steering Problem
    By phrogs4life in forum VX Talk...
    Last Post: 10/18/2012, 11:56 PM
  3. How to drain power steering
    By VXNIT in forum VX Talk...
    Last Post: 10/02/2010, 06:48 PM
  4. Power steering pump going out?
    By Grif in forum VX Troubleshooting...
    Last Post: 08/26/2010, 08:44 PM
  5. High idle/ high power steering pressure?
    Last Post: 09/22/2007, 04:21 PM
Tags for this Thread
