Results 1 to 15 of 23
Thread: Igor's Upringing
    May 2016
    2001, Kaiser Silver, Vehicross 1376
    Igor's Upringing
    So I've decided to keep track of the modifications/repairs done to my VX on here. Like any auto enthusiast, the mod itch doesn't stop at just one thing.
    2016:
    -Purchased in March. 130k on the odometer. All stock
    -Replaced amber side markers and front turn signals with clear lenses
    -Removed chrome nerf bars
    -Installed new radiator due to small crack.
    -Replaced OEM speakers with Infiniti speakers.
    -Installed light bar in lower grille opening
    -Installed OEM roof racks
    -Replaced passenger window glass while trying to fix power windows issue
    -Installed power window brackets from SBC
    -Made a garage door opener using the spare button on the center console
    -Removed ABS bulb from dash
    -Installed light bars on roof rack
    -First attempt at painting the sun faded plastic cladding (fail)
    2017:
    -New tires. BF Goodrich Baja Champion KO2s installed
    -Installed OME 912 lift. Gained 2.5"
    -Painted plastic cladding using bedliner spray (success!)
    -Installed tailgate opener using 10lb solenoid (fail)
    -Re-worked tailgate opener using 35lb solenoid (success!)
    -Replaced front pads and rotors
    -Painted front brake calipers yellow
    -Installed bracket and 65lb gas shock to hold tailgate open
    -Attempted to wrap VX (fail)
    -Installed remote tailgate opener switch to outside of vehicle
    -Sound deadened interior using Dynamat and insulation foam
    -Wrapped light bars in yellow
    -Installed Samsung tablet as new infotainment center
    -Current mileage: 161k
    2018 Plans:
    -Wrapped the truck in satin Urban Jungle by Avery Dennison
    -Sprayed black bedliner on door B pillars to match the plastic cladding bedliner spray
    2019 & 2020 updates:
    -Installed "flip out" back up camera in the half moon piece. Works automatically when in reverse and can be controlled via pushbutton as well
    -Upgraded to LED light bulbs
    -Passed the 200k mile mark
    Future Plans:
    -Manual transmission swap
    -Wheels and tires upgrade (thinking 33" on Fuel D564 Beast wheels)
    -Upgrade engine cooling (thermostatic fan delete, upgrade radiator, automated hood vents)
    -Replace gas shock on rear hatch with linear actuator
    Thanks for reading and I will keep you posted. If you have any questions, feel free to ask
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    Pics!
    May 2016
    Pics are under my username in Member Photos. Unfortunately, I can't load all pics due to storage space restrictions.
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    I have actually never been able to use the member gallery section. For some reason it wont take any of my attempt to upload. I did find a way to use Dropbox to post pics though.
    http://www.vehicross.info/showthread...r-forum-images
    It may help.
    May 2016
    Not that anything is wrong with my powertrain but, I had an idea last night.....How compatible do you think the 3.6L LLT V6 from the 2010-2102 Camaros would be in our VehiCrosses? I used to own a 2010 Camaro V6 and it had some gusto to it. I like the idea of this engine for the following reasons:
    - 304hp and 273lb-ft of torque
    - It's a 60* GM V6 so it "should" be compatible with our transmissions
    - The Aisin AY6 should bolt up to the T.O.D. transfer case for a manual transmission option
    - It weighs slightly less than the 6VE1 (375lbs vs 361lbs)
    - Fuel economy is awesome, though I know this will change because the Camaro V6 had 3.27 axle ratio and the Vehicross has a 4.30 ratio.
    - New parts are still available for this engine unlike the 6VE1
    As much as I would LOVE to have a V8 under the hood, I think this V6 (or it's LFX sister) might be our best option. I'm going to toil over this and maybe undertake a new BIG project
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    Bolting it up, I would think, would be strait forward enough. May need to fab some motor mounts. The trick is going to be the TOD. If you can get that sorted I think you will be on to something.
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Skip to next post (I duped somehow).
    Feb 2010
    Thanked: 19
    Depends on which computer you used.... If both computers have basically the same capability (ODB2?) computer, I'd wonder if you can "flash" the VX ECM with the parms necessary to get the newer V6 working correctly? Certainly, that would be a lot easier than installing an engine harness -- though many would consider that route. I know many/most of the reasons the newer engine has better power relates to mechanical design improvements. What I don't know is if there are any critical sensors NOT present on the VX? Even on my ODB1 (89) Corvette, the computer had the ability to code injector parameters...to cover how they behave with different voltages, etc... FIC (fuel injector connection) could likely provide parameters...or point you to them for the injectors. That's the hard part (to me).
    As long as you could fuel the newer engine correctly, I'd think you'd still get the performance improvement you'd expect. Am I missing something? Were there any engine sensors developed to operate 2010 engines not present in 2001?
    May 2016
    The LLT for the Camaro was a Direct Injection motor so I know the fuel pressure would be way higher. I know this doesn't mean much, but the OBD Torque App I use had a few more sensor options when plugged into the Camaro than the Isuzu. Engine oil pressure, engine oil temperature and transmission temperature are only a few I can think of off the top of my head that are present in the Camaro and not the 6VE1.
    Feb 2010
    Thanked: 19
    Odd....My 89 Vette has oil pressure and temp. Even if the VX doesn't "use" those temp/pressure parms, I'm thinking it won't matter if those sensor bungs are plugged. Or....maybe the VX computer IS capable of displaying them...if extra gauges were installed? I'm guessing FP doesn't matter either. It's computer wouldn't "know" if you fed a new engine much higher pressure....just like the VX doesn't know how you've set it's AFPR. My first thought/question is whether they the newer motor uses O2 sensors that could adjust AFR on the fly?
    The bigger thing I considered -- after my prior post -- is whether the 2010 engine has variable valve timing? My daughter had a 2003 Volvo that did. I don't know if/how it's computer differed to handle that...or if they are mechanically activated (rather than electronically)?
    Obviously, you could pin-out a newer ECM...and run add'l lines not present. Knowing how wire looms are made/routed, that seems easier than tearing apart a dash.
    Have you considered a supercharger instead? Might be less work to get similar gains?
    Mar 2015
    Thanked: 34
    Subbed.
    May 2016
    The paint on my VX is faded after 17 years of life. I have decided to make things interesting and attempt to wrap him. Also, I'm in the midst of a flip down back up camera. I started with the hatch fearing it would be the most difficult part to wrap. Surprisingly, not that difficult. The bet I had with my wife is that if I could wrap the most difficult part, then I have the go ahead and wrap the rest. What do you think?
    ][IMG][img]/gallery/data/500/thumbs/Igor_Wrap2.jpg[/img][/IMG]
    That green is a great choice!
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    Love that green!
    May 2016
    Thank you! The wrap is Avery Dennison Urban Jungle - satin finish.
