Results 16 to 23 of 23
Thread: Igor's Upringing
Threaded View
    May 2016
    2001, Kaiser Silver, Vehicross 1376
    Igor's Upringing
    So I've decided to keep track of the modifications/repairs done to my VX on here. Like any auto enthusiast, the mod itch doesn't stop at just one thing.
    2016:
    -Purchased in March. 130k on the odometer. All stock
    -Replaced amber side markers and front turn signals with clear lenses
    -Removed chrome nerf bars
    -Installed new radiator due to small crack.
    -Replaced OEM speakers with Infiniti speakers.
    -Installed light bar in lower grille opening
    -Installed OEM roof racks
    -Replaced passenger window glass while trying to fix power windows issue
    -Installed power window brackets from SBC
    -Made a garage door opener using the spare button on the center console
    -Removed ABS bulb from dash
    -Installed light bars on roof rack
    -First attempt at painting the sun faded plastic cladding (fail)
    2017:
    -New tires. BF Goodrich Baja Champion KO2s installed
    -Installed OME 912 lift. Gained 2.5"
    -Painted plastic cladding using bedliner spray (success!)
    -Installed tailgate opener using 10lb solenoid (fail)
    -Re-worked tailgate opener using 35lb solenoid (success!)
    -Replaced front pads and rotors
    -Painted front brake calipers yellow
    -Installed bracket and 65lb gas shock to hold tailgate open
    -Attempted to wrap VX (fail)
    -Installed remote tailgate opener switch to outside of vehicle
    -Sound deadened interior using Dynamat and insulation foam
    -Wrapped light bars in yellow
    -Installed Samsung tablet as new infotainment center
    -Current mileage: 161k
    2018 Plans:
    -Wrapped the truck in satin Urban Jungle by Avery Dennison
    -Sprayed black bedliner on door B pillars to match the plastic cladding bedliner spray
    2019 & 2020 updates:
    -Installed "flip out" back up camera in the half moon piece. Works automatically when in reverse and can be controlled via pushbutton as well
    -Upgraded to LED light bulbs
    -Passed the 200k mile mark
    Future Plans:
    -Manual transmission swap
    -Wheels and tires upgrade (thinking 33" on Fuel D564 Beast wheels)
    -Upgrade engine cooling (thermostatic fan delete, upgrade radiator, automated hood vents)
    -Replace gas shock on rear hatch with linear actuator
    Thanks for reading and I will keep you posted. If you have any questions, feel free to ask
