Project VXOverLand
					30 June 2017 I purchased my first ever VX! Ebony #0209!
Here it is as it sits today: 01 September 2018 (this pic will be updated as things change)
Down to business...
The VX:
Vehicle: 1999 Isuzu Vehicross
Last Four: 0209
Color: Ebony
Engine: Factory 3.5L V6
Transmission: Factory Auto
Current Wheel Size: 16"
Current Tire Size: 265/70R16
Plan for project: The plan is fairly simple. Prove that you can build a daily driver / Overland Vehicle without the need to drop $40,000+ on the base vehicle before you even get started, and look good doing it!
Total Spent: $7,500
Completed Repairs/Upgrades/Modifications:
-  Repair Bad Brakes (All of them) (Complete)
-  Remove Vinyle Wrap (Complete)
-  Get Transmission Working (Complete)
-  Replace Battery (Complete)
-  Passenger Door Exterior Window Seal Missing (Complete)
-  Drivers Door not opening from outside (Complete)
-  Recondition Yellowed Head Lights (Complete)
-  Get Replacement Keys Made (Complete)
-  Transfer Case Fluid Change (Complete)
-  Build/Buy Bracket for Battery Tray (Complete)
-  Install Sound System (Complete)
-  Recondition/Replace OEM Sterio Antenna (Complete)
-  Replace Front Half Shafts (Complete)
-  Fix EGR error code (P0405) (Complete)
-  Get A/C serviced (works but makes a lot of clicking noise) (Complete)
-  1 or 2 Inch Lift (Complete)
-  Recondition Winshield Wiper Arms. (Complete)
-  31 Inch Tires (Firestone Destination A/T @ 265/70/R16)(Complete)
-  Fix high idle issue(Complete)
-  CB Radio (Complete)
-  Winch (Badlands 12,000lbs) (Complete)
-  Winch Mount (Complete)
-  Trailer Hitch Install (Complete)
-  Repair leaks in the windshield washer system. (Complete)
-  Full Engine Service (Complete)
-  Install Transmission Shift Solenoids (Colmplete)
-  Repair door window motors (Both Sides) (Complete)
-  Diagnose and repair ABS Light (Complete)
-  Repair Door Window Tilt Issue (Complete)
-  Install Auxiliary Fuse Block Under Hood (Complete)
-  Install Brush Gard (Complete)
-  Change Diff Fluid (F/R) (Complete)
Planned Repairs/Upgrades/Modifications:
-  Install Trailer Light Plug (Plug & Additional Wiring Installed but not functioning)
-  Repair Drivers Front Fender (Changed to repair after closer inspection)
-  External Spare Tire Mount w/ Fuel Can Holder (Trooper Tire Carrier Purchased)
-  Rock Sliders
-  Install Switch Panel (Purchased (Installed USB ports, still waiting to get switches))
-  Install Storage System
-  Install Manual Locking Hubs
-  Install “Blue Wire Mod” for TOD interrupt
-  (Will Add More As I think of things, but that is enough for today)
Work Log:
30 June 2017: Purchased the VX
01 July 2017: Started to remove the faux carbon fiber vinyl wrap (Drivers Door, Drivers Rear Quater Panel, Rear Door complete)
02 July 2017: Weather was wonkey, so I replaced the transmission filter, both pan gaskets, and new synthetic fluid. Also added 1 Quart of Lucas Oil "Transmission Fix".
03 July 2017: Removed more of the faux vinyl wrap. Still have Roof, Metal part of the hood, and plastic grill surround to do.
04 July 2017: Ordered Weather Strip for the exterior passenger door.
04 July 2017: Removed vinyl wrap from hood.
07 July 2017: Repaired driver door not opening from outside.
08 July 2017: Got three replacement keys made.
09 July 2017: Finished removing all the Vinyl Wrap
10 July 2017: DIY Solution found for door weather strip
10 July 2017: Got license plates and went for first test drive. Break issue discovered.
11 July 2017: Unstuck dragging break caliper. New "groan" noise detected, attempting to diagnose.
13 July 2017: Confirmed order for weather trip for exterior passenger door.
13 July 2017: Ordered Blue Tooth OBD2 Reader
13 July 2017: Diagnosed "groan", low transmission fluid, I didn't buy enough and it was lower than I thought.
15 July 2017: Checked for error codes with OBD2 scanner. P0113 and P0405
15 July 2017: Verified Transmission Fluid Levels
17 July 2017: Conducted first shake down drive.
19 July 2017: Cleaned and polished headlight after removing headlight pod.
19 July 2017: Reinstalled headlight pods.
21 July 2017: Cleared all OBD2 Error codes but P0405 (EGR).
21 July 2017: Conducted General Maintenance around engine bay.
22 July 2017: Tranfer case fluid change complete.
22 July 2017: Discovered numerous leaks in the windshield washer system.
23 July 2017: Discovered Rear Brakes not working
24 July 2017: Purchased Rear Break Pads. Storms Preventing Install Today.
24 July 2017: Purchased and installed battery bracket (Universal Fit)
30 July 2017: First attempt at installing OEM window seal failed.
31 July 2017: New front speakers on order.
31 July 2017: New head unit on order & waiting to ship.
31 July 2017: Clips for Window Strip on order, waiting to ship.
31 July 2017: Devious Plans still in development.
31 July 2017: Possible cause of 0405 error code found.
01 August 2017: Tried last possible cause of code 0405, failed.
04 August 2017: Replacement Head Unit finally ships. Finally!
05 August 2017: Head Unit and speakers arrived today!
07 August 2017: Head Unit Installed. Need to finalize mount.
08 August 2017: Head Unit Install complete.
11 August 2017: Started Rear Brake Work, issues discovered
15 August 2017: Replaced one (1) rear lug stud
15 August 2017: Finished Rear Brakes! Finally! (M:167357)
16 August 2017: Replaced OEM radio antenna
25 August 2017: Ordered replacement half axles for the front.
01 September 2017: Installed new front brake pads.
01 September 2017: Installed new front axle half shafts.
01 September 2017: Inpected and repacked front wheel bearings.
01 September 2017: Installed exterior window seal clips.
04 September 2017: Installed EGR Valve (P0405 now clear)
15 September 2017: Installed replacement air filter box
15 September 2017: Installed replacement brake booster hose
15 September 2017: Cleaned the MAF sensor
23 September 2017: Installed New Air Filter
23 September 2017: Installed New MAF Sensor
23 September 2017: Installed New 130 Amp Alternator
24 September 2017: Tightened up steering box, removed play from steering
25 September 2017: A/C system seems to be working normal again.
14 October 2017: Site was down, performing work log update.
14 October 2017: Installed new throttle position sensor.
14 October 2017: Installed new idle are control valve.
14 October 2017: Purchased a number of engine parts to install this weekend.
14 October 2017: Purchased Old Man EMU suspension (shocks and coils) to be installed this weekend.
14 October 2017: Began cardboard modeling of winch mount/off-road bumper.
14 October 2017: Removed/Replaced/Repaired more wiring.
15 October 2017: Lift Kit Installed, driver window motor quit.
21 October 2017: Replace Fuel Pressure Regulator on fuel rail.
22 October 2017: Replaced intake and throttle body gasket.
22 October 2017: Fixed driver window not going up all the way.
24 October 2017: Ordered the OEM VX CrossBars today. Hopefully they will ship on the 26th.
25 October 2017: New tires and alignment.
29 October 2017: Installed new intake manifold gasket.
30 October 2017: Fixed high idle issue! Yay!
31 October 2017: OEM Yakima Roof Bars for the VX installed.
10 November 2017: Installed a Reese Roof Basket, Phone Mount, and a 2nd new upper intake manifold gasket.
15 November 2017: Ordered a Curt Hitch from e-trailer.com
24 November 2017: Completed CB Radio Install.
25 November 2017: Purchased Winch. Curt Hitch Arrived.
20 December 2017: ABS Light came on
26 December 2017: Removed Crash Bumper
26 December 2017: Started to build winch mount
30 December 2017: Completed fabrication of winch mount
31 December 2017: Installed Winch Mount and Winch (Not wired up yet)
01 January 2018: Winch wired and working, pulled steel cable off
13 January 2018: Trailer Hitch Install Completed
23 January 2018: Installed passenger window motor. Window now tilts
10 February 2018: Window Washer leaks seems to have fixed themselves. Probably dry seals.
16 February 2018: Dropped at a shop for an entire engine workup.
20 February 2018: Got the VX back from the shop, new EGR valve installed (yes, again)
24 February 2018: Did the SeaFoam clean due to an EGR related CEL, codes staying clear for now.
07 March 2018: Pulled and cleaned the “Mode Selector/Neutral Safety Switch”.
17 March 2018: Replaced all five shift solenoids.
17 March 2018: Replaced the transmission mount.
17 March 2018: Replaced the transmission filter.
24 March 2018: Conducted Fuel System Pressure Test
24 March 2018: Replaced Fuel Filter
25 March 2018: 1st Successful test drive with no issues what so ever.
30 March 2018: Finally changed the spark plugs.
31 March 2018: Drilled the plastic “grill” to allow winch clutch access.
02 April 2018: Got dash switch mount inserts.
06 April 2018: Attempted a “window” fix, passenger side. New regulator required.
12 April 2018: Greased window tracks both sides.
21 April 2018: Purchased A/C Condesor Fan.
21 April 2018: Purchased Heated, Leather, Power seats.
01 May 2018: Purchased In Channel Rain Gaurds.
04 May 2018: Installed WeatherTech In Channel Rain Gaurds.
25 May 2018: Reinstalled A/C Condenser Fan.
25 May 2018: Installed wireless winch controller.
25 May 2018: Removed after market car alarm.
25 May 2018: Removed Rear Seat.
26 May 2018: Test fit replacement seats. Failure.
31 May 2018: ABS System repaired.
06 June 2018: Repaired Passenger Window Function.
15 June 2018: Purchased new TPS
15 June 2018: Purchased RTV for transmission pan
16 June 2018: Fixed leak in transmission
16 June 2018: Installed BlueSea Fuse Block under hood
18 August 2018: Replaced both front brake calipers and pads
27 August 2018: Lost Key to Lug Nuts (Will have tire shop remove them)
27 August 2018: Obtained Fog Light & 4WD switch from another Isuzu
27 August 2018: Obtained Brush Gaurd
01 September 2018 Brush Guard Installed
30 September 2018 Replaced rear speakers
27 October 2018 Started to work on the Transmission Shift Shaft Seal
28 October 2018 Finished Shift Shaft Seal replacement.
03 November 2018 Changed Differential Fluid (F/R)
09 November 2018 Replaced Throttle Position Sensor (Second New One)
23 November 2018 Replaced lower intake manifold gasket (drivers side failed).
23 November 2018 Discovered failing MAF. Will attempt to clean before replacing.
30 November 2018 Installed new MAF.
31 December 2018 installed new TPS.
19 January 2019 Painted Cladding
17 February 2019 Removed Rear Seatbelts
01 July 2019 Passenger Window Motor Failed
					Reason: Updates
