Based on this thread ( http://www.vehicross.info/showthread...ght=Window+fix ) I tried the roller baring window fix.
First I pulled the entire regulator and cleaned it up. Even sitting out of the door without the weight of the window it had “sticky” spots. I lubed it up as best I could but some still remained. The little plastic bits are just plain worn out, lots of flopping around.
I decided to try it out anyway and went ahead with the roller. I didn’t have much hope at this point, but what the heck, I had it apart already.
No dice.  The regulator is just to far gone. Sine they cost a shiny penny or two, this fix will have to wait. My driver window already mostly works, so the roller may work on that side, but the passenger window will need replacement parts.
Dang it.
